Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Forums > Network & Internet
problem with uploading small files to FTP
Thread Tools Display Modes
Old 06-10-2008   #1 (permalink)
Newbie
  ipeople is offline
I have problem with uploading lots of small files to FTP over Vista. I tried few programs for FTP transfer and it doesn't resolve problem. If I uploaded big files (100 - 300 MB) FTP transfer working fine, but if I uploaded lots of small files (100 x 5 Kb etc.) connection was terminated after few files transfered (every 20 - 50 files). Error message is "server connection failed". If I try this on same computer with Win XP it is work fine.
Any idea?
Thanx
Old 06-10-2008   #2 (permalink)
sidney1st's Avatar
  sidney1st is offline
Re: problem with uploading small files to FTP
What happens if you change the Number of Simultaneous Connections to 1
Old 06-10-2008   #3 (permalink)
Newbie
  ipeople is offline
if I change number of simult. con. to 1, it doesn't have any effect to this
Old 06-10-2008   #4 (permalink)
garysgold's Avatar
Geek
  garysgold is offline
Hi ipeople,
I've been using WS FTP95 LE for a couple months now with no problems.
Gary
Old 06-10-2008   #5 (permalink)
johngalt's Avatar
Antidisestablishmentarian
  johngalt is offline
*I* personally recommend FileZilla - it's fast, and it's free, and it is actively developed.
FileZilla - The free FTP solution
Old 06-11-2008   #6 (permalink)
Newbie
  ipeople is offline
Hi, I was trying FileZilla and another programs and some of them can reconect lost connections autommaticly, but problem is not resolved - during uploading small files, connection is broken for many times. Using this programs is can help me, but I relly want know what is cause, because in Win XP it is working fine ....
Old 06-12-2008   #7 (permalink)
johngalt's Avatar
  johngalt is offline
Have you applied any system tweaks, such as disabling autotuning or increasing the number of simultaneous connections in IE?
Old 06-12-2008   #8 (permalink)
sidney1st's Avatar
Well, have a look in your ftp client configuration, in FileZilla you have many options regarding your problem.
The other thing to do is to try uploading with the firewall disabled to check if the problem don't come from this side.
Display Modes
entering Sleep mode whilest downloading /uploading files mukkadaz Vista General 1 04-15-2008 09:24 PM
Uploading a files from video camera bobby needs some help Vista music pictures video 0 04-01-2008 04:52 PM
Copy Files Dialog Too Small Axel Dahmen Vista General 2 03-10-2008 07:07 PM
Video files playing small stavesacre Vista music pictures video 1 02-02-2008 06:37 PM
deleting 20 small files take 3 minutes Summercool Vista General 2 01-31-2008 06:10 AM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
