Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Forums > Network & Internet
Remote Desktop help!!
Update your Vista Drivers Update Your Drivers Now!!
Thread Tools Display Modes
Old 06-18-2008   #1 (permalink)
Junior Member
Vista Ultimate 32bit
bpfeil is on a distinguished road
  bpfeil is offline
I recently set up my remote desktop on my Vista Ultimate. Everything was working good, I could access it from the other Vista computer on my network and the Xp one. I also set up a dyndns account to access it outside of my local network. I configured both my firewall and my router for remote access also. The problem I'm having is now just out of the blue I can't access the computer from anywhere. Not the Vista or the Xp computer and certainly not outside of the network. I've gone through all my settings and everything is set up the same. I get an error off of the Xp mechine that says "An authentication error has occured (Code: 0x80090330). I'm trying to access with the ip address becasue using the computer name never worked for me.
Old 06-18-2008   #2 (permalink)
sidney1st's Avatar
Ultimate SP1 x64 & x86
Paris
sidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond repute
  sidney1st is offline
Re: Remote Desktop help!!
The error means that "the specified data could not be decrypted"
Old 06-18-2008   #3 (permalink)
Junior Member
  bpfeil is offline
so how do I fix this so i can use remote desktop?
Old 06-18-2008   #4 (permalink)
sidney1st's Avatar
Paris
On the client side, how did you configure? Did you choose: Always connect, even if authentication fails ?
Old 06-18-2008   #5 (permalink)
Junior Member
  bpfeil is offline
thats how its been setup
Old 06-18-2008   #6 (permalink)
sidney1st's Avatar
Paris
OK, so try to enable the "enablecredsspsupport:i:0" option in the default.rdp, it should solve your problem (i hope)
Old 06-18-2008   #7 (permalink)
Junior Member
  bpfeil is offline
Where do i access that? And I'm guessing i do it on my vista computer running the remote desktop?
Old 06-18-2008   #8 (permalink)
sidney1st's Avatar
Paris
You have to add this option in the rdp file
Old 06-18-2008   #9 (permalink)
Junior Member
  bpfeil is offline
where do i access the rdp file?
Old 06-18-2008   #10 (permalink)
sidney1st's Avatar
Paris
If you did not move it, it should be in your "Documents" folder.
You can edit it with notepad
Display Modes
remote desktop moves desktop icons ChuckN Vista General 2 04-20-2008 09:10 PM
Can't login to remote comp. using Remote Desktop Connection on Vis Luigi_1996 Vista account administration 0 12-13-2007 10:14 PM
Remote Desktop problem with remote printers neworders@gmail.com Vista networking & sharing 0 02-11-2007 10:55 AM
remote desktop connection? AKA remote access? menachem Vista General 1 02-05-2007 11:41 PM
Remote Desktop - Able to have one user logged in locally and one user via remote desktop? Paul Murdock Vista networking & sharing 3 10-20-2006 04:54 AM
Update your Vista Drivers Update Your Vista Drivers Now!!
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
