Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Forums > Network & Internet
Remote Desktop Help
Update your Vista Drivers Update Your Drivers Now!!
Thread Tools Display Modes
Old 07-04-2008   #1 (permalink)
Computer-Ed's Avatar
Junior Member
Vista Ultimate x64
Computer-Ed is a glorious beacon of lightComputer-Ed is a glorious beacon of lightComputer-Ed is a glorious beacon of lightComputer-Ed is a glorious beacon of lightComputer-Ed is a glorious beacon of lightComputer-Ed is a glorious beacon of light
  Computer-Ed is offline
Remote Desktop Help
Okay you networking gurus I need some help. I have a machine at home running Vista and one at work running Vista and would like to use remote desktop to my work machine so I can work from home when I need to. I am hoping I can use the setup in Vista without having to buy Gotomypc.
I can make the remote desktop work flawlessly in the office between two machines but I cannot access my office from home for some reason.
Anyone with experience at this HELP!
Old 07-04-2008   #2 (permalink)
johngalt's Avatar
Antidisestablishmentarian
Vista Ultimate x64 MAK
3rd Rock
johngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant future
  johngalt is offline
Re: Remote Desktop Help
RD will require various special ports forwarded on your router (if you have one) and ports allowed in your firewall (Vista by default has a firewall, so even if you haven't installed one it is there) before you can do it.
Another solution would be to use VPN, see the VPN thread in this forum as well.
Old 07-08-2008   #3 (permalink)
Junior Member
Vista Ultimate x64
Can you giveme the port info to setup the roputer or point me to the location of the information?
Old 07-08-2008   #4 (permalink)
Freelancer852's Avatar
Vista Vet
Vista Ultimate x86 (32bit) w/SP1
Canada, Alberta
Freelancer852 is a jewel in the roughFreelancer852 is a jewel in the roughFreelancer852 is a jewel in the roughFreelancer852 is a jewel in the rough
  Freelancer852 is offline
Computer-Ed, try looking here:
PortForward.com - Free Help Setting up Your Router or Firewall
I find that they have almost EVERYTHING you need when it comes to router/firewall issues.
Display Modes
remote desktop moves desktop icons ChuckN Vista General 2 04-20-2008 09:10 PM
Can't login to remote comp. using Remote Desktop Connection on Vis Luigi_1996 Vista account administration 0 12-13-2007 10:14 PM
Remote Desktop problem with remote printers neworders@gmail.com Vista networking & sharing 0 02-11-2007 10:55 AM
remote desktop connection? AKA remote access? menachem Vista General 1 02-05-2007 11:41 PM
Remote Desktop - Able to have one user logged in locally and one user via remote desktop? Paul Murdock Vista networking & sharing 3 10-20-2006 04:54 AM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
