| Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks. |
| | LinkBack | Thread Tools | Display Modes |
| Junior Member ![]() | Remote Desktop Help Okay you networking gurus I need some help. I have a machine at home running Vista and one at work running Vista and would like to use remote desktop to my work machine so I can work from home when I need to. I am hoping I can use the setup in Vista without having to buy Gotomypc. I can make the remote desktop work flawlessly in the office between two machines but I cannot access my office from home for some reason. Anyone with experience at this HELP! |
| Antidisestablishmentarian ![]() ![]() ![]() | Re: Remote Desktop Help RD will require various special ports forwarded on your router (if you have one) and ports allowed in your firewall (Vista by default has a firewall, so even if you haven't installed one it is there) before you can do it. Another solution would be to use VPN, see the VPN thread in this forum as well. |
| Junior Member ![]() | Re: Remote Desktop Help Can you giveme the port info to setup the roputer or point me to the location of the information? |
| Vista Vet ![]() | Re: Remote Desktop Help Computer-Ed, try looking here: PortForward.com - Free Help Setting up Your Router or Firewall I find that they have almost EVERYTHING you need when it comes to router/firewall issues. |
| Display Modes | |
| remote desktop moves desktop icons | ChuckN | Vista General | 2 | 04-20-2008 09:10 PM |
| Can't login to remote comp. using Remote Desktop Connection on Vis | Luigi_1996 | Vista account administration | 0 | 12-13-2007 10:14 PM |
| Remote Desktop problem with remote printers | neworders@gmail.com | Vista networking & sharing | 0 | 02-11-2007 10:55 AM |
| remote desktop connection? AKA remote access? | menachem | Vista General | 1 | 02-05-2007 11:41 PM |
| Remote Desktop - Able to have one user logged in locally and one user via remote desktop? | Paul Murdock | Vista networking & sharing | 3 | 10-20-2006 04:54 AM |
