| Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks. |
| | LinkBack | Thread Tools | Display Modes |
| Member | Download Speed Problem with FlashGet Hi everyone. I'm using Flashget and when I try to download (currently a .torrent file) the speed remains LESS THAN 1KB and the time Left is 00:00:00!!!! ![]() Anyone else use FlashGet 1.9? When I was installing it I placed in another Drive (non-OS). How can I optimize the settings to get the most out of my connection (512kbps)? I already have given it an exception from Windows Firewall. Any help is greatly appreciated. ![]() If you want any more details, post them and I will provide the info. MANY MANY THANKS!! (Vista Forums is a regular visit for me and 9/10 has the answer I need ). Last edited by Witch-King-of-Angmar; 08-25-2008 at 10:19 AM.. Reason: Incorrect Spelling |
| Antidisestablishmentarian ![]() ![]() ![]() | Re: Dowload Speed Problem with FlashGet have you tried with another BitTorrent client to see if it is FlashGet or if it is simply that the torrents you're trying to get are not available? |
| Member | Re: Dowload Speed Problem with FlashGet I haven't tried any other yet. Got any recommendations? I heard that uTorrent and Vuze (formerly Azereus) are the best. I'll try uTorrent first. Many, many thanks for your help. |
| Flim-Flam Man ![]() | Re: Dowload Speed Problem with FlashGet How many peers are you connected to? |
| Member | Re: Dowload Speed Problem with FlashGet |
| | #6 (permalink) |
| Flim-Flam Man ![]() | Re: Dowload Speed Problem with FlashGet I don't know where that info would be found in Flashget, it's a download manager and I wouldn't expect it to be great for torrent usage (although it has the capability). In utorrent there are "seed" and "peer" columns to show how many are available and how many your are connected to. ![]() But in order for your PC to see the torrents and the other way around and you are behind a router/hardware firewall then you have to forward ports to get connected. PortForward.com - Free Help Setting up Your Router or Firewall ...and then you need to configure uTorrent to work the best for your situation. AfterDawn.com: Guides: Using and Maxing Out Speeds With uTorrent But before you do anything you need to protect yourself with Peerguardian or ipfilter. |
| | #7 (permalink) | |||||||||||||||
OK. I got uTorrent 1.8 & PeerGuardian 2 (Beta for Vista). I followed that great guide on AfterDawn.com (had to be changed slightly because the guide did not follow uTorrent 1.8 directly). I only have one problem now: Portforwarding. I clicked on your link (PortForward.com - Free Help Setting up Your Router or Firewall) but my router isn't there (Arris Touchstone CM550 A/B Cable Modem). Even so, I have noticed an improvement when downloading a random torrent (as a test). ![]() I was just wondering, if I can get the router to forward a port, could my ISP disconect me from the internet (is it illegal)?. Again, I'm new to this stuff. Many many thanks for your help. | |||||||||||||||
My System Specs![]() | ||||||||||||||||
| | #8 (permalink) |
| Flim-Flam Man ![]() | Re: Dowload Speed Problem with FlashGet Your routers config should probably be close to the Arris TM552 ~ http://www.portforward.com/english/r...2/Utorrent.htm Most company's use a generic interface that is practicly identicle from model to model and usually only adds different features Last edited by locoeng; 08-26-2008 at 09:55 AM.. Reason: added link |
| | #9 (permalink) | |||||||||||||||
![]() I was giving the wrong info! I do use the Arris Touchstone, but it is connected to a Wireless Router! Buffalo WHR-G-125! Through PortForwarding, I was able to successfully set it up for uTorrent! Many many thanks and sorry for forgetting about my Buffalo .Thanks a million - Problem solved! | |||||||||||||||
| | #10 (permalink) |
| Flim-Flam Man ![]() | Re: Dowload Speed Problem with FlashGet Glad you got it sorted...congrats |
| Display Modes | |
| Flashget or Getright compatible for Vista 64bit? | army | Software | 4 | 04-24-2008 11:43 AM |
| 65 mb or 427 mb sp1 dowload? | shortstop643 | Vista General | 7 | 04-13-2008 08:59 PM |
| Dowload updates from hp.com | Hunter James | Vista General | 9 | 06-06-2007 05:36 PM |
| Problem downloading/Flashget/DAP | Synapse Syndrome | Vista General | 3 | 03-13-2007 06:00 AM |
| 64bit dowload problem! | Tommy | Vista General | 2 | 06-22-2006 02:27 AM |
