DLINK DWA-142 installation problems in Vista 64bit
Phoenix
~ Please keep in mind that I'm from the Netherlands, so my English will not be as perfect as yours ;) ~
Like the title suggests I'm experiencing a lot of problems when I try to install my wireless adapter, the D-Link DWA-142.
Before I bought the DWA-142, I mailed DLINk with the question if the DWA-142 supported both vista 32 and 64 bit editons. Dlink confirmed that and replied with an 100% compatibility statement.
When I try to install the adapter with the supplied driver disc, I am experiencing errors like: Cannot install wireless driver, or: Cannot find wireless adapter. When I use the add hardware wizzard he does not 'see' the disk...
I also tried to install with windows XP SP2 compatibility.. Same results.
Note: When I plug the USB adapater in, VISTA is aware of it but the DLINK installation wizzard isn't.. How wierd is that...
How can I solve this?
DLINK said it was 100% compatible with X64 and X86 Vista based systems, so yes I am sure...
Just seen on Dlink US web site: http://support.dlink.com/products/view.asp?productid=DWA-142
attachment.php
I'm requested a RMA at my hardware shop. I'm going to swap the DWA-142 for the DWA-556, which is actually Vista x64 compatible.
Thanks for the good research.. ;)
