Vista - THe Problem I had.............
Closed Thread
Old 05-10-2008   #1 (permalink)
Vista Ultimate x32
I had a problem in XP where do to connectivity problem my PC used to get hanged after installing this software version. Now using Vista Ultimate full version internet problems had got just better and it alerts me or i can see what type of problem occured as whether server problem or no connection due to bad weather.
Congrats to Vista!
Closed Thread
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
