| Vista Ultimate 32bit | Remote Desktop help!! I recently set up my remote desktop on my Vista Ultimate. Everything was working good, I could access it from the other Vista computer on my network and the Xp one. I also set up a dyndns account to access it outside of my local network. I configured both my firewall and my router for remote access also. The problem I'm having is now just out of the blue I can't access the computer from anywhere. Not the Vista or the Xp computer and certainly not outside of the network. I've gone through all my settings and everything is set up the same. I get an error off of the Xp mechine that says "An authentication error has occured (Code: 0x80090330). I'm trying to access with the ip address becasue using the computer name never worked for me. |
| Ultimate SP1 x64 & x86 | Re: Remote Desktop help!! The error means that "the specified data could not be decrypted" |
| Vista Ultimate 32bit | Re: Remote Desktop help!! so how do I fix this so i can use remote desktop? |
| Ultimate SP1 x64 & x86 | Re: Remote Desktop help!! On the client side, how did you configure? Did you choose: Always connect, even if authentication fails ? |
| Vista Ultimate 32bit | Re: Remote Desktop help!! thats how its been setup |
| | #6 (permalink) |
| Ultimate SP1 x64 & x86 | Re: Remote Desktop help!! OK, so try to enable the "enablecredsspsupport:i:0" option in the default.rdp, it should solve your problem (i hope) |
| | #7 (permalink) |
| Vista Ultimate 32bit | Re: Remote Desktop help!! Where do i access that? And I'm guessing i do it on my vista computer running the remote desktop? |
| | #8 (permalink) |
| Ultimate SP1 x64 & x86 | Re: Remote Desktop help!! You have to add this option in the rdp file |
| | #9 (permalink) |
| Vista Ultimate 32bit | Re: Remote Desktop help!! where do i access the rdp file? |
| | #10 (permalink) |
| Ultimate SP1 x64 & x86 | Re: Remote Desktop help!! If you did not move it, it should be in your "Documents" folder. You can edit it with notepad |
| Remote desktop can not find remote computer | Network & Sharing | |||
| Can't login to remote comp. using Remote Desktop Connection on Vis | Vista account administration | |||
| Remote Desktop problem with remote printers | Vista networking & sharing | |||
| remote desktop connection? AKA remote access? | Vista General | |||
| Remote Desktop - Able to have one user logged in locally and one user via remote desktop? | Vista networking & sharing | |||
