Vista - vista wireless problems
Old 06-23-2008   #11 (permalink)
Ultimate SP1 x64 & x86
Re: vista wireless problems
What controller type is it? new one from Dell?
1/ Try to test the speed with your firewall/AV disabled and first of all test the laptop being close to the router.
2/ Check with Dell if you use the latest drivers for the controller.
3/ In properties you should have:
WWM deactivated
WIFI mode: g
If you are configured for more than one network, remove all except your home network.
Vista wireless problems Vista General
Wireless Problems in Vista Network & Sharing
Vista 64 SP1 Wireless Connection Problems Vista networking & sharing
TCP/IP problems in Vista - with WIRELESS Vista networking & sharing
