Vista - AR5007EG connection problems
Old 08-06-2008   #1 (permalink)
Vista Home Premium
I'm having problems connecting to a wireless network that is not broadcasting it's SSID with my labtop that has an AR5007EG wireless network adapter
I can connect to the network with other computers
The router I use is a linksys WRT150 set to b/g with WPA2 encryption
I have searched the forum and the internet but could not find a solution
Can someone help me
Old 08-06-2008   #2 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
Re: AR5007EG connection problems
Hi, jimboike, and welcome to the forums.
have you searched LinkSys's' forums?
Old 08-07-2008   #3 (permalink)
Vista Home Premium
Hi johngalt,
thanks for your reply. no I didn't search the linksys forums because this problem accured only with my new labtop running vista home premium, with my other systems still running XP I don't have any problems.
I will follow up your advise and post it if i find a solution
Atheros AR5007EG Problems with WEP and WPA Network & Sharing
Atheros AR5007EG Problems in Vista 32bit Network & Sharing
connection problems Vista mail
IE 7 Connection problems & Windows Mail Connection Vista General
TCP/Ip connection problems Vista mail
