Vista - wireless printer problem
Old 09-11-2008   #1 (permalink)
Home premium 32 bit
I bought a Lexmark wireless printer today and I'm trying to connect my laptop to it using the same router that I access the internet with. How can I find my Network or Security Key as required to get a connection? I have no idea what the key is to my router.
Old 09-11-2008   #2 (permalink)
Vista Ultimate 64bit SP2/
Re: wireless printer problem
What is the make and model of your router?
Problem with Dell printer after installation of Vista SP2 (printer prints an extra page) Vista General
Having problem resetting wireless printer Vista print fax & scan
Problem with Network printer over wireless network. Vista print fax & scan
Problem printing in Wireless printer Vista print fax & scan
Network Printer and Wireless Network problem Vista installation & setup
