Vista - Bluetooth problems
Old 09-12-2008   #1 (permalink)
Vista Home Premium 64bit
Bluetooth problems
My bluetooth wont work i have my network switch on. I use a wireless switch and i dont see the option for bluetooth there. I believe i have installed the drivers and when i go to device manager i dont see anything bluetooth related along with anything in my control pannel. Any help would be appreciated. Btw my computer is a compal JHL90. And when i run the bluetooth software update it says no bluetooth device was detected.
Thanks,
Clayton
Old 10-26-2008   #2 (permalink)
vista Ultimate x64
Re: Bluetooth problems
I have exactly the same problem on Vista Ultimate 64. I have a BTO notebook, with the COMPAL JHL90 Mainboard. The manufacturer didn't have a solution either (the notebook was delivered with vista 32 bit)
Bluetooth problems Vista hardware & devices
Bluetooth problems with Vista Vista General
Major Bluetooth Problems Drivers
Bluetooth LogitechMX5000 Problems Vista installation & setup
