| Vista Home Premium (64-bit) with SP1 | Need help with IE7 Sorry if this isn't the right section for this question, but I am new to this Forum. I made a IE7 Personalized Home Start page and the Weather gadget I added can not be viewed because the entire window is not visible. It only shows part of the gadget viewing window. Is this a problem with Vista or IE7? I have the same gadget on my Windows XP computer and there isn't a problem. How do I correct this? |
