Vista - Problems with Internet Connection
Old 10-15-2008   #11 (permalink)
Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64
Re: Problems with Internet Connection
Thanks SIW2, but as I mentioned in my last post I was constantly getting a download speed of 3500+ Kbps all day yesterday (14th) from 1-30 PM to 10-30 PM (UK time) AND the phone did ring several times without any negative effects on the tests.
Here is another check that I have made (I have removed my MAC address). Note that my IP addresses are dynamically assigned by AOL and therefore do change.
Notice the %Loss at Hop 2 which is my current 'Gateway IP Address'. If you cannot decipher it, it is 20%.
Old 10-15-2008   #12 (permalink)
If you follow this link: thinkbroadband :: Search and then enter 'aol' into the 'Words to search for' box followed by clicking on 'Submit' you will find a lot of reports on similar issues to what I am having - slow download speeds. Nothing is mentioned about this on the AOL site - it has nothing to report under 'System Status'.
Old 10-16-2008   #13 (permalink)
I have just applied for my MAC code. Look at these figures. Bearing in mind that I was on the phone to them at that time, don't you think that it was a bit of a coincidence with the last test (9:00 PM)?
Old 11-12-2008   #14 (permalink)
I am now with O2, and the Internet feels much more responsive already. I was actually connected yesterday afternoon (11/11/08). I left the router on overnight to allow the connection to stabilise, hence the difference in speed between yesterday and today. This shows the benefit of leaving the router switched on, even if the rest of the system is turned off.
internet connection problems Browsers & Mail
internet connection problems Network & Sharing
Internet connection problems Vista networking & sharing
Re: internet connection problems Vista networking & sharing
