Vista - problem with internet connection
Old 11-04-2008   #1 (permalink)
Vista Home Premium 32bit
hi!!!
config:dell wireless 1395 WLAN mini card
well when i try to connect to internet (we have well working wi-fi connection over here) it takes long time,internet page is not displayed .it says waiting for this-this site for virtually very long time,where the same adjacent lap can connect within fraction of seconds,it never says unable to connect internet.interestingly if i restart lap then it connects quite normally,seems like connection goes to saturation with time.i can guaranty that no problem is with wi-fi network,acess is always shown local & internet.LAN works normally.
i have installed latest WLAN card driver,still problem remains & performed tests available to check hardware & network problems which shows no fault was found
sometimes half the site loads & half not....it takes long duration of "redirection"...in device manager out of 18,4adapters were marked namely Microsoft 6to4 adapter #2
Microsoft 6to4 adapter #3
Microsoft 6to4 adapter #4
Microsoft 6to4 adapter #5
i checked dere solution online but in vain.....
i have network meter in sidebar which shows zero internet signal with some LAN signal when net does not work... but other computer can operate at the same time...after restarting everything becomes all right....
PLZ Guide..
Aharnish
INDIA!!!
Old 11-05-2008   #2 (permalink)
Vista Ultimate 64
Re: problem with internet connection
I had the same problem with my internet connection on a recent reinstall of Vista Ultimate 64 on a rebuild of my computer. The internet connnection ran great when I first installed Vista and the manufacturer included chipset drivers and Lan drivers. Once I did Windows Update I did not notice that it had installed new Window drivers for the onboard LAN. I uninstalled the Windows Driver and installed the most up to date drivers from the motherboard manufacturer's website and it solved all the porblems. Nice stable connection now. Windows Update still wants to install their drivers every time I update but I just uncheck them and do not install them. Hope this helps.
Internet Connection Problem Browsers & Mail
Problem With Internet Connection...Please Help. Browsers & Mail
Problem with my internet connection Vista networking & sharing
Internet connection problem Vista General
Internet Connection problem Vista General
