Vista - LAN Problem
Old 11-25-2008   #1 (permalink)
Vista Home Premium 32bit
LAN Problem
My LAN is not detected after installed VISTA in my system. Can someone help me in finding LAN driver.
Regards,
Sudhir V
Old 11-25-2008   #2 (permalink)
Windows 7 RC x64 Vista HP x86
Re: LAN Problem
Hello SudhirKam, welcome to the Vista Forums
Could you please give some more information,
What Hardware is involved?
Wired, or Wireless?
Are any messages shown?
What have you tried?
If you can post back with more details I'm sure someone will be able to help
Old 11-25-2008   #3 (permalink)
Re: LAN Problem
Yep. Thanks for the response. Its a wired network. I got vista starter installed in my system. And then I tried to install the drivers in my system. I got response from all the drivers installed, except the LAN Driver. LAN driver which i installed now is not getting supported with vista OS. The LAN which i installed was Realtek GBE & FE Ethernet PCI NIC Driver. Will this information be helpful to solve the problem?
Old 11-25-2008   #4 (permalink)
Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64
Re: LAN Problem
Hi Sudhirkam,
What is the make and model of your motherboard?
Old 11-25-2008   #5 (permalink)
Re: LAN Problem
Its actually HCL system. Not assemled. So I could not check with that.
Is there any other way i can find it out?
Old 11-25-2008   #6 (permalink)
Re: LAN Problem
Hi SudhirKam,
A quick search found this driver ...
Download REALTEK GbE & FE Ethernet PCI NIC Driver 6.101 Driver for Windows Vista - Softpedia
You may want to download and install this driver ...
hope this helps
Old 11-25-2008   #7 (permalink)
Re: LAN Problem
Hi SudhirKam,
Here is a link to the HCL website: hcllaptops.com. Have a look at this and see if you can identify your system here. Note that HCL don't appear to actually manufacture systems, rather they are a retailer.
Old 11-25-2008   #8 (permalink)
Re: LAN Problem
Hi that link was really useful but the corresponding download is not found...
Is there any other link?
Old 11-25-2008   #9 (permalink)
Re: LAN Problem
Hi dwarf, What you told is correct... Can i have any other way to look into the details for motherboard ...
Old 11-25-2008   #10 (permalink)
Re: LAN Problem
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
