Vista - wireless problem
Old 12-04-2008   #1 (permalink)
vista home basic
wireless problem
Ok here is what my laptop computer is doing
all of a sudden my wireless connection stopped working, so i did a system restore and it started working again, then it made the updates, and it stopped working again, the system restore worked twice and then after the updates, not working again, this time more permanent, when the computer starts it tells me that the bluetooth is on, but no existence of the wlan, the driver doesn't even show up on the device manager.
Then after some time my computer became stuck it didn't respond (this due to a different issue) so I decided to force the computer to turn off, when it restarted i had a wireless conection, then I turned off the computer and when I turned it back on no internet again, then I decided to try the force turn off again, and again I had internet.
also if i have the internet working and i close my computer the internet stops working as well
does anyone know how i can solve this problem?, I can't be forcing the computer to turn itself off all the time
Thank you
Mauricio
Old 12-04-2008   #2 (permalink)
Vista Home Premium SP2 32bit / Windows 7 Home Premium 32 bit
Re: wireless problem
Can you give us a few more details about your setup ?
Is your connection to your own network or work or while roaming, what network card does your machine use.
Sorry I know nothing about laptops but if you could give the experts here as much information as possible with regards your machine and who it is you connect to like your ISP, that would help them provide you with help.
Old 12-04-2008   #3 (permalink)
vista home basic
Thanks.
i connect to a home network, I don't know much about the card except that 802.11 AGN wlan
Old 12-04-2008   #4 (permalink)
We still need more information to be able to help, who is your ISP what updates did you do, do you have a router you could connect to via an Ethernet cable to check if you can connect that way.
Sorry to ask so many questions but without more information we can't tell what might be wrong, it could be the wireless card gone bad or your ISP is having problems, it could be anything and without more details it will be difficult to solve
Old 12-04-2008   #5 (permalink)
vista home basic
lets see
ISP is Road runner, through Time Warner Cable
the computer conects fine with a cable to the router, but not wireless.
there are two other computers in my house, but they conect to the internet wireless just fine.
something I forgot to mention, I thought at first it was the wireless card so i check with HP since i still had warranty, after many things that included reinstaling the card and the drivers they sent me another card thinking that that was the problem, this one didn't work either, then I did the full system restore and the wireless worked fine until the updates, donno which updates it made, the only one I remember is the service pack 1 aside from that I can't remember.
let me know if you need more info
Old 12-04-2008   #6 (permalink)
Have you looked at Windows Updates by clicking on the start orb then in the program list, that should tell you what updates were installed and when.
I know this is a silly question but you did remember to switch the wireless back on after the updates, as I said I know nothing about laptops but believe there is a switch that turns on the wireless part or maybe it's some key combination ?
Don't think I'll be able to help anymore so you may have to wait for one of the experts to join in, plus I'll be shutting down for the night in about half an hour and it will be late tomorrow before I'm back online.
Old 12-04-2008   #7 (permalink)
Windows 7 RC x64 Vista HP x86
Hi MPinzon, and Welcome to the vista forums ,
As joan has said may need further info as we go along but first,
Can you see the wireless signal in the network and sharing centre?
You mention bluetooth and also 802g lan card, is this a standard wireless connection or via bluetooth?
Is this a secured wireless network?
What if any firewall are you running on the machine?
If you can post back with this info will try to guide you through some testing to diagnose the fault
Old 12-04-2008   #8 (permalink)
vista home basic
1. it appears when the computer recognizes the wireless conection, when it doesn't it only shows the conection through a cable.
2. I think is via bluetooth, but i'm not sure, I've also heard mention in regard to my problem from the HP support center something about an NVIDIA controler.
3. yes it is a secure network.
4. I had the windows firewall as well as the norton one, when the problem stated to appear I turned the windows one off first, when this didn't solve the problem i did the same with the Norton one leaving the windows on, and then both off and still didn't work
Old 12-05-2008   #9 (permalink)
Hi Mauricio
First thing to check is the drivers
Check on the device manager under the network adaptor branch for your network card drivers, ( as this may be bluetooth the entry may be on another branch, so you may have to look around for it a bit ).
Right click on the driver entry and you should see a Power Management Tab. On this tab make sure the "allow the computer to turn off the Device to save power" is off (un-ticked).
Sometimes this feature may cause the system to switch off the adaptor and cause the network to drop, (unfortunately it's not as good at turning it back on)
Of course if this is a Bluetooth device the range of these is not the same as a conventional wireless card and may be at the limit of it's range
Old 12-08-2008   #10 (permalink)
vista home basic
Thank you Barman, I did what you sugested, it didn't work, the laptop is still not connecting
wireless problem .NET General
wireless problem Vista networking & sharing
wireless problem Vista General
Wireless problem Vista networking & sharing
