Vista - simple problem
Old 02-15-2009   #1 (permalink)
vista ultimate X64
simple problem
where is that checkbox???where you can turn on and off DEP for a certain program....please help.
Old 02-15-2009   #2 (permalink)
Vista Ultimate 64bit SP2/
Re: simple problem
This should answer your question.
DEP - Turn On or Off for Programs
Old 02-15-2009   #3 (permalink)
Windows 7 RC x64 Vista HP x86
Re: simple problem
Try
Computer - properties - advanced system settings - performance settings - data execution protection -phew !!!
problem with very simple tcpclient in powershell PowerShell
Simple Intellitype pro problem? Drivers
Help with simple keyboard problem General Discussion
Simple Vista-XP network problem Vista networking & sharing
