| vista home | problem with LAN hi, i've, having a problem connecting to the internet via ethernet cable. in the networking panel it tells me the ethernet cord is unplugged, but it is (and i've tried other cables, from other wall outlets) and the ethernet controller is enabled. i have reason to believe someone may be playing a prank on me, and changed some setting, but i have no idea what could be done, other than disabling the ethernet controller in the control panel, would make it so that the laptop doesn't see the ethernet cord. thank you in advance! |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
