| vista home 32bit | network printer problem I have vista home 32 bit on a laptop and a desktop I have two Kodax printers one on my desktop one on my wifes desktop. I have them both shared however I can not get my laptop to conect to either one I see the printers on the network but every time I tell them to add I get a message telling me I typed the name wrong I didn't type a name I chose a printer from the list. I allso have the same problem trying to connect my desktop to my wifes printer. I have spent hours on the phone with HP and they couldnot resolve the problem. I called microsoft and they would not help because both units are under warinty with Hp. Any help |
| windows vista ultimate | Re: network printer problem Hi Tangnuts, We need more infomation to help you please specifiy wheter you can share files with yours wifes desktop. Are you able to do file shareing is it only the printer. also check on vista in the network and sharing center wheter printer sharing is enabled. if this is disabled enable it. else pls reply with more details. Hope this helps Cheers !! |
| vista home 32bit | Re: network printer problem Im sorry it takes so long to get back I don't get on a computer very often. I can share files on all computers its only a printer problem I tried it in safe mode with networking and with the firewall turned off and still wont work. I tried selecting avalable shared printers (they both show up on printers shared) but I get a message I typed the name wrong I tried changing the names of the printers still would'nt work I can see the new names but still get a message I typed the name wrong. I'm at a real loss. |
| Windows 7 Home Premium x64 | Re: network printer problem |
| vista home 32bit | Re: network printer problem Thanks that worked. I'm Surpriced Microsoft doe'nt have it posted on there site. |
| Network Printer problem | Vista print fax & scan | |||
| problem with my network printer | Network & Sharing | |||
| Network printer problem | Vista print fax & scan | |||
| Problem with Network printer over wireless network. | Vista print fax & scan | |||
| Network Printer and Wireless Network problem | Vista installation & setup | |||
