| Windows Vista home Premium SP1 | popup blocker problem I NEVER get popups, wich is A GREAT thing. Its just that I have my internet explorer 7 vista popup blocker set to show info bar and play sound when a popup tries to get through. when ever I go to a site a on my machine and then I go to the same site on another machine, neiher of us get the popup but he gets the bar and the sOUND. Why dont I get the bar or sound. My security software does not have a popup blocker and I dont even have 1 toolbar installed |
| Vista Home Premium 64 bit SP1 | Re: popup blocker problem If it ain't broke, don't fix it. You might end up with lots of popups and lots of noise. |
| Windows Vista home Premium SP1 | Re: popup blocker problem whats blocking the popups though? |
| Popup Blocker IE8 Problem | Network & Sharing | |||
| Re: Good content blocker/site blocker for Vista workstation? | Vista security | |||
| Re: Good content blocker/site blocker for Vista workstation? | Vista General | |||
| popup blocker location | Vista General | |||
