| Vista Ultimate x32 | LAN problem i just updated my vista from home premium to ultimate. however the lan in new vista is not working. when i press lan button it still shows red ..not blue unlike earlier. i re installed the software of HP wireless Assistant which was in my earlier version of Vista.but when i press the LAN button it says that my Lan is disabled From Device Manager .when i got to device manager , there is no Wireless LAN present there. the help also says to use Computer Setup Utility (DOS) (F10) then use system configuration >then built in device options where Switch on lan. but my trouble is there is no BUILT IN DEVICE OPTION in there DOS. what should i do??????? |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
