| Vista Home Premium x64bit | Connection problem It appears that I do have a very serious connection problem, which has popped up suddenly out of nowhere with no sensible explanation. When I go to "Connect to a Network" I see that my connection has only one of five bars, with the connection status listed as "Low." When I go to "Control Panel>Network and Sharing," and "View Status" I see that the "IPv6 Connectivity" is listed as "Limited." I removed the "Microsoft 6to4 adapter" previously because it had a yellow exclamation point listed next to it in my Device Manager after having read on the Internet that it could be deleted without any side effects if a person can't get it working, which was what I did. I now see that the "IPv6 Connectivity" is listed as "Limited" when I go to Control Panel\Network and Sharing Center, and am wondering if this is due to my having removed the 6to4 adapter even though the system said it wasn't functioning properly. But I didn't have this slow connection problem until just the last couple of days, and I deleted the 6to4 adapter over a week ago. Last edited by Brink; 05-22-2009 at 02:59 PM.. Reason: Moved and changed thread title |
| Win7x64 | Re: Connection problem IPv6 has nothing to do with "slow" or "one of five bars" wireless connectivity issues. Try first of all verifying whether everything works normally when you're connected to the router with a wire. If so, then obviously the wireless NIC is somehow part of the problem, and you should first consider updating its drivers. Beyond that, if signal strength is now much lower than it used to be, think about what may have changed from an environmental perspective. Has someone knocked down the antenna on the router? Is there a new source of RF interference in the vicinity? Who moved that sheet of nuclear-fallout-shelter lead in between the router and the PC? |
| Vista Home Basic 32bit | Re: Connection problem IPv6 has nothing to do with "slow" or "one of five bars" wireless connectivity issues. Try first of all verifying whether everything works normally when you're connected to the router with a wire. If so, then obviously the wireless NIC is somehow part of the problem, and you should first consider updating its drivers. Beyond that, if signal strength is now much lower than it used to be, think about what may have changed from an environmental perspective. Has someone knocked down the antenna on the router? Is there a new source of RF interference in the vicinity? Who moved that sheet of nuclear-fallout-shelter lead in between the router and the PC? peace |
| Vista Home Premium x64bit | Re: Connection problem I'm not using wireless, but I found out that the problem is attributable to a new hook-up for the neighbor, which split my cable line and has caused me to lose signal strength. :::sigh::: But my PC was acting very strange as a result of it, and initially I had thought it might be a memory problem rather than a connection issue. |
| Vista Home Basic 32bit | Re: Connection problem I'm not using wireless, but I found out that the problem is attributable to a new hook-up for the neighbor, which split my cable line and has caused me to lose signal strength. :::sigh::: But my PC was acting very strange as a result of it, and initially I had thought it might be a memory problem rather than a connection issue. peace |
| | #6 (permalink) |
| Vista Home Premium x64bit | Re: Connection problem The funny thing is that when this line was hooked up a couple of years ago, one of the cable company's guys who came for a follow-up visit (I forget why) had told me that there were too many connections on that telephone hub that my line was hooked up to. I had forgotten about that -- and they ran a new line for me yesterday, I'm assuming to that same box/hub that I was connected to previously, which now also has the neighbor hooked up there too, who's still connected to my old line; they kept him on the same connection I had been on and ran a completely new line for me, and I noticed when watching MSN videos a little while ago that the videos were choppy while playing, so I think I may actually have to call these people yet again to tell them things still aren't entirely right perhaps. :::sigh::: |
| | #7 (permalink) |
| Vista Home Basic 32bit | Re: Connection problem The funny thing is that when this line was hooked up a couple of years ago, one of the cable company's guys who came for a follow-up visit (I forget why) had told me that there were too many connections on that telephone hub that my line was hooked up to. I had forgotten about that -- and they ran a new line for me yesterday, I'm assuming to that same box/hub that I was connected to previously, which now also has the neighbor hooked up there too, who's still connected to my old line; they kept him on the same connection I had been on and ran a completely new line for me, and I noticed when watching MSN videos a little while ago that the videos were choppy while playing, so I think I may actually have to call these people yet again to tell them things still aren't entirely right perhaps. :::sigh::: peace |
| | #8 (permalink) |
| Vista Home Premium x64bit | Re: Connection problem [quote=kikidee;1049985][quote=ccantare;1049906]The only choice I would have in that case would be to go with DirecTV, because there's only one cable company in this neck of the woods; they have a cable monopoly here. But I'm going to give it until after tomorrow to see how things go, because some video plays well, some not so well, so I'm going to test it out some more. Last edited by ccantare; 05-25-2009 at 05:35 PM.. |
| | #9 (permalink) |
| Vista Home Premium SP2 32bit / Windows 7 Home Premium 32 bit | Re: Connection problem kikidee you sent me a private message, which I replied to, but you are not recieving PM's so it wouldn't send. |
| | #10 (permalink) |
| Vista Home Basic 32bit | Re: Connection problem |
| problem with connection | Network & Sharing | |||
| another connection problem | Vista networking & sharing | |||
| Connection problem | Vista security | |||
| Connection Problem | Vista performance & maintenance | |||
| Connection problem | Vista General | |||
