I am not able to connect my pc with internet when I was trying to shift it on different default gateway. Currently I have two default gateways; one is 192.168.1.1 and second is 192.168.0.1. I have ten PCs, Out of 10 and 8 PCs are on 192.168.1.1. And two PC are on 192.168.0.1, these two PC are automatically getting there IP address with default gateway 192.168.0.1. So I want to put these two PCs on 192.168.1.1, so manually I changed the default gateway to 192.168.1.1 but after this , these two PC’s was no longer active their connectivity to the internet vanished. So is there any solution to put these two PCs on 192.168.1.1 default gateway???
Beside that when I was trying to view network connection , the next 9 PCs are not available , means some available and some not , same situation for every PC , If I individually check view network connection some PCs are available but some not.
Second thing I want to add every PC on same workgroup, so can I able to accessible each document of share drive from each PCs
So anyone knows solution for both problems…????
Thanks very much
