Vista Tutorial - wireless network problem
Old 07-04-2009   #1 (permalink)
Vista Home Premium 32bit.
Hi I just got a new laptop from HP, I use Vista Home Premium 64-bit. I set up my wireless network. It ran fine. But everytime that I close the computer or get it out of the hibernate, althought the wireless connection "seems" to be working, I cannot access to any site. Once I reboot the wireless, then 70% of the time it'll be fine again. Any suggestions to this problem?
Old 07-04-2009   #2 (permalink)
Master
Vista home premium 32bit
Re: wireless network problem
Check the "Idle Timeout" in the Basic Settings of the router.
Old 07-04-2009   #3 (permalink)
I checked the timeout. It is fine. My girlfriend has another laptop. Hers never gets disconnected and it is on all the time.
Problem with Network printer over wireless network. Vista print fax & scan
Wireless Network Problem Vista networking & sharing
Wireless network problem Vista networking & sharing
Network Printer and Wireless Network problem Vista installation & setup
