Please help the technical meek
kd70
Just moved and unloaded my Laptop and Desktop. Prior to moving both worked fine on the wireless connection.
Now, everything is plugged in and on, wireless connection signal is strong as ever but I can no longer search the Internet, just says, "the address is not valid" with the generic IE screen.
What happened? Most threads are about new computers, these are not new, everything was find until I moved.
Help!
Do you use broadband?
If so have you told the broadband company you have moved?
I would check your router to ensure it can get the internet.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
