Vista - xbox live connection problems
Old 07-18-2009   #1 (permalink)
Vista Home Premium 32bit
ok guys iv done some research and i want to know if everything ive done is correct and if theres some other things i can do. i have got a wireless xbox adapter to my belkin N1 vision router version 1001. please dont tell my to make it LAN because then id have to run a 50m cable through my house so its not an option.
i have pute my xbox in the DMZ that solved NAT problems.
i have tried port forwarding and i think i have done it right not sure. also i did enable QoS but it made my downloads really slow and my internet speed slow.
any thing else you have in mind? here are some pictures.
Old 07-18-2009   #2 (permalink)
Windows Vista Ultimate X86
Re: xbox live connection problems
well if it works properly and NAT is open then everything is done fine.
Xbox Live Messenger Connection Issues Live Messenger
xbox live connection problems Network & Sharing
Problems with network connection and xbox live Gaming
Internet Connection Sharing, Windows Vista and Xbox Live Vista networking & sharing
365 Days Later, Xbox 360 Unveils First Wave of TV Shows and Movies on Xbox Live Vista News
