| x86 32bit | problem with network card HI all, Just bought a new acer apire m3641 and with that pc an sitecom 300n wireless pci card xr. (opperating system vista home premium) I installed the software and drivers first then i put the card in it but after boot the utility says the card doesn't exist. Also when i look at the hardware tab of the properties of this computer it doesn't show the network adapter. When i look at the back of the computer both of the leds on the network card are burning so i means it has power. Does anybody know how to fix this problem?? thanks Mark |
| Vista 32 win 7 7600 32 bit | Re: problem with network card metal mike one way to be sure is to go into device manager by typing that in search. go to the network tab and see if your wifi caard is listed there and working correctly. If it is either not there or has a yellow triangle on it, it means the driver isnt properly installed or the wrong driver. Let us jnow the status and if you are 32bit or 64 thanks ken |
| Network card problem | Network & Sharing | |||
| Which Network Card? | Network & Sharing | |||
| Network card problem | Vista hardware & devices | |||
| help with second network card | Vista General | |||
