Hey all
Since i built my computer I have been having fight with other family members over the internet as our router broke and we have to plug right into the modem (only one can connect at a time). Today i purchased a 8 port 10-100mbps network switch (Buying a router is not possible at this time) I connected the modem to the switch, then my computer and then the home computer. When i connected on my computer, everything was fine (I have vista ultimate x64 sp2.) I then disconnected and connected the home computer (xp Pro sp3) Everything worked fine. Then I came back to mine and tried to connect and after a bit of waiting i got the message "Error 815" and that the server is not responding. When I do the opposite and connect my computer and then try connect the xp computer, I get the message "Error 676 the line is busy."
I can browse both the computers files through network as long as I have the other computers password.
Does anyone know a solution to my problem so that both computers can be online at the same time e.g. a shared internet connection from vista pc to xp pc or connect to the internet through the other computer and vice versa?
Any help would be greatly appreciated!
P.S Both computers have kaspersky internet security but i tried disabling them and it still didnt work
- Custom Built
- Core 2 duo 2.2GHz
- Foxconn 45CMX
- 2gb
- Graphics Card(s)
- nVidia 8500 gt 1gb
- RaLink
- 17'' Samsung lcd
- 160gb Sata
- PSU
- 500Kw Zixa
