| Vista Home Premium | Wifi connection problem Hi i just bought an Acer netbook with windows vista home premium. I have tried to connect it to my home router and everytime i do it ask for a pin number. so i finally got the pin number off the router and typed it in and then it went to a network security page or something like that and i connected it then. But my question is how can i connect to routers say like at my classroom when i can't get the pin number off the router? I mean my gf's comp has vista on it and so does my brothers ones home premium and ultimate, and all they do is say connect to, then choose the router and put in the password and they are connected? they are both only about a month newer than mine but how can i get mine to do that and not the pin number deal? thanks |
| Vista 32 win 7 7600 32 bit | Re: Wifi connection problem Hi i just bought an Acer netbook with windows vista home premium. I have tried to connect it to my home router and everytime i do it ask for a pin number. so i finally got the pin number off the router and typed it in and then it went to a network security page or something like that and i connected it then. But my question is how can i connect to routers say like at my classroom when i can't get the pin number off the router? I mean my gf's comp has vista on it and so does my brothers ones home premium and ultimate, and all they do is say connect to, then choose the router and put in the password and they are connected? they are both only about a month newer than mine but how can i get mine to do that and not the pin number deal? thanks Its the way your router is set up. You can turn that off in the router web page which you got a glimpse of. using a browser type in the address (varies) and then click enter the usual web page is 192.168.0.1 Hope this helps Ken |
| Windows 7 Ultimate x64/Vista Ultimate x64/XP Pro x86/Fedora 12 X64 | Re: Wifi connection problem if you are saying that you need to put in a pin number every time you connect to a router. when you are choosing the network you want to connect to tick the boxes save this network and automatically connect, this will save you from having to input your password every second |
| Vista Home Premium | Re: Wifi connection problem Its the way your router is set up. You can turn that off in the router web page which you got a glimpse of. using a browser type in the address (varies) and then click enter the usual web page is 192.168.0.1 Hope this helps Ken[/QUOTE] Sorry im kinda new to this but i type that in to say my internet explorer and then i should get that number and put that into where? thanks |
| Windows Vista Enterprise x64 SP2 | Re: Wifi connection problem Sorry im kinda new to this but i type that in to say my internet explorer and then i should get that number and put that into where? thanks[/QUOTE] When you are in class, there is a high probability they will NOT require any access codes. Security on wireless routers, if established, use schemes like WEP, WPA, WPA2, etc. You certainly want to run security with your own router. Otherwise people outside your house, apartment or flat can - at best - access your internet and - at worst - obtain personal information. |
| | #6 (permalink) |
| Vista Home Premium | Re: Wifi connection problem ya i had a password on the router its a belkin, and i reset it and it still asked for a pin number. but on all the other laptops, all it ask for is the password and then connected to the router. so is there a way i can fix this? |
| | #7 (permalink) |
| Windows Vista Enterprise x64 SP2 | Re: Wifi connection problem |
| | #8 (permalink) |
| Vista Home Premium | Re: Wifi connection problem ok i did that, so does that mean that now i wont have a pin number on my comp later if i try to connect to other routers? or do i need to turn the WPS off on my Laptop? thanks |
| | #9 (permalink) |
| Windows Vista Enterprise x64 SP2 | Re: Wifi connection problem Whoa. Maybe I misunderstood that part. Have you been asked for pin numbers on other routers? If so, please give me make and model of your wifi, as well as pc. |
| | #10 (permalink) |
| Vista Home Premium | Re: Wifi connection problem ya i get asked it on other routers sorry i probably wasnt very clear because i didn't know how to explain it correctly. The laptop is a acer AS1410 this is the WLAN on the sticker on my laptop ACer Nplify 802.11a/b/g/Draft-N this is what is says on my device manager Intel (R) WiFi Link 5100 AGN thanks |
| WiFi Connection keeps dropping | Network & Sharing | |||
| WiFi looses connection | Drivers | |||
| SP1 WiFi connection keeps getting disconnected | Vista networking & sharing | |||
| Slow WiFi connection during startup | Vista General | |||
| Automatic WiFi Connection | Vista networking & sharing | |||
