Network speed problem.
ingeborgdot
Pain In The Butt
Power User
As I continue to test the network speed I am truly baffled. My local area connection shows 1.0Gbps. The computer on the other end shows the same but when I go to download to the other computer I get speeds between 16-20 MB/s. I know there are many variables but holy cow. What can I do?
My problem is still that there seems to be a problem between my one computer running vista 64bit and windows xp pro on the other one. I have enabled jumbo frames and nothing changes. The computer is an AMD quad core computer 4400+. That should be able to handle what I was feeding it. I changed hdd and that did not make a difference except to give me my needed space for the computer I was needing. The gig lan is a built in lan to the mobod of the computer. I don't have a NAS yet as I tried one but it was not very good.
Would buying a pci lan card be the way to go for this computer as I will use it for alternative backups etc.
Could a new nic card in each computer maybe make a difference? The cards would be exactly the same. The one mobod is around 6 years old the other maybe 4. The lan that I have are on the mobod. Just a thought.
    Genuine Home Built Grad A
    Q6600
    Abit IP35Pro
    4GB Crucial Ballistix
    VisionTek Radeon HD4850
    HT Omega Claro
    Sansung SyncMaster 2493HM
    1900x1200
    2 - internal seagate 500GB
    1 - external 2TB NDAS server
    P&C quad 750 watt
    Antec P182
    6016kbps
    Q6600
    Abit IP35Pro
    HT Omega Claro
    1900x1200
    P&C quad 750 watt
    Antec P182
    6016kbps
This is what someone told me in another forum. What is true about this?
For 1Gbit LAN to work, you'll need GBLan adapters and cables (yes, these are different than
"Normal" CAT-5 cables) in all devices on your network, including switches & routers.
I did not think routers would affect it after it is hooked up to the switch.
My network goes like this. Internet in to a 2wire modem/router-----gig switch-----computer-- also from the gig switch------ to another switch in another room------ to another computer, bluray, denon 3808CI, NAS(soon).
    Q6600
    Abit IP35Pro
    HT Omega Claro
    1900x1200
    P&C quad 750 watt
    Antec P182
    6016kbps
    Q6600
    Abit IP35Pro
    HT Omega Claro
    1900x1200
    P&C quad 750 watt
    Antec P182
    6016kbps
Look at it this way, just because everything is a Gigabyte connection does NOT mean you will achieve those speeds. Downloading files from a local host or server is limited to that servers hardware capabilities, like the hard drive specifically. The CPU and the network card play roles but you can not base your speeds solely on the network. The network is built to handle it, yes, but the end devices can not successfully implement those speeds due to hardware limitations other than the network.
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Acer
    Touchpad
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
