Local Only Problem - LAN and Wi-Fi
  1. #1
    iya
    Newbie
    Singapore
    Vista Home Premium 32bit
    Local Time: 11:33 AM
    Hi everyone
    I am using an HP laptop on Windows Vista Home Premium 32bit. I recently encountered "Local Only" connection problem via LAN with a new ISP. I've been using my laptop for over 2 years and I never encountered this problem before with my previous ISP. I was also still able to connect successfully to the Internet with wireless connections.
    Yesterday, I tried to remedy the problem with what was prescribed in (Microsoft Support), but it did not fix the problem. What's worse is that when I tried connecting via wi-fi today, it would not work either--the "Local Only" problem also surfaced all of a sudden. Wi-fi connection via iPhone was perfectly fine, so it is my laptop that is problematic. I am now only able to connect via dial-up/mobile internet.
    I hope you can help me with this. Please let me know what details would be helpful for this query.
    Thanks a lot!
  2. #2
    iya
    Newbie
    Singapore
      Thread Starter
    Re: Local Only Problem - LAN and Wi-Fi
    Here are further details on my machine. Hope you guys can help!
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : Zarina
    Primary Dns Suffix . . . . . . . :
    Node Type . . . . . . . . . . . . : Hybrid
    IP Routing Enabled. . . . . . . . : No
    WINS Proxy Enabled. . . . . . . . : No
    PPP adapter StarHub:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : StarHub
    Physical Address. . . . . . . . . :
    DHCP Enabled. . . . . . . . . . . : No
    Autoconfiguration Enabled . . . . : Yes
    IPv4 Address. . . . . . . . . . . : 113.10.118.164(Preferred)
    Subnet Mask . . . . . . . . . . . : 255.255.255.255
    Default Gateway . . . . . . . . . : 0.0.0.0
    DNS Servers . . . . . . . . . . . : 203.116.1.94
    203.116.254.150
    Primary WINS Server . . . . . . . : 10.11.12.13
    Secondary WINS Server . . . . . . : 10.11.12.14
    NetBIOS over Tcpip. . . . . . . . : Disabled
    Wireless LAN adapter Wireless Network Connection:
    Media State . . . . . . . . . . . : Media disconnected
    Description . . . . . . . . . . . : Broadcom 802.11b/g WLAN
    Physical Address. . . . . . . . . : 00-1A-73-2D-27-0B
    DHCP Enabled. . . . . . . . . . . : Yes
    Ethernet adapter Bluetooth Network Connection:
    Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
    Physical Address. . . . . . . . . : 00-1A-6B-23-5E-CD
    Ethernet adapter Local Area Connection:
    Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
    Physical Address. . . . . . . . . : 00-1B-24-C5-2B-6E
    Link-local IPv6 Address . . . . . : fe80::600c:1f87:7351:2c01%8(Preferred)
    Autoconfiguration IPv4 Address. . : 169.254.44.1(Preferred)
    Subnet Mask . . . . . . . . . . . : 255.255.0.0
    DHCPv6 IAID . . . . . . . . . . . : 201332278
    NetBIOS over Tcpip. . . . . . . . : Enabled
    Tunnel adapter Local Area Connection* 6:
    Description . . . . . . . . . . . : isatap.{3A958D30-E198-480E-B568-5A9CD3003
    1CA}
    Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
    Link-local IPv6 Address . . . . . : fe80::5efe:169.254.44.1%16(Preferred)
    Tunnel adapter Local Area Connection* 7:
    1CA}
    Tunnel adapter Local Area Connection* 10:
    Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
    Tunnel adapter Local Area Connection* 11:
    Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
    Physical Address. . . . . . . . . : 02-00-54-55-4E-01
    Tunnel adapter Local Area Connection* 12:
    Description . . . . . . . . . . . : isatap.{3F9ED315-D90E-429E-BF6A-C0EDAF154
    534}
    Tunnel adapter Local Area Connection* 13:
    Description . . . . . . . . . . . : isatap.{1D5D5847-AA46-4006-B3DB-92A45ADDC
    C8A}
    Tunnel adapter Local Area Connection* 14:
    Description . . . . . . . . . . . : Microsoft ISATAP Adapter #6
    Link-local IPv6 Address . . . . . : fe80::200:5efe:113.10.118.164%29(Preferre
    d)
    203.116.254.150
    Tunnel adapter Local Area Connection* 15:
    Description . . . . . . . . . . . : 6TO4 Adapter
    Temporary IPv6 Address. . . . . . : 2002:710a:76a4::710a:76a4(Preferred)
    Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
    203.116.254.150
  3. #3
    MDA400's Avatar
    Nvidia and Intel
    Bloomington, MN
    Vista Home Premium x64 SP2
    Local Time: 09:33 PM
    usa us minnesota
    Hello Iya and welcome to the Vista Forums.
    If your using a Wireless adapter on your laptop, is it turned on? or is the router configured properly to recieve your router's signal?
    Some people commonly forget that their internal wireless adapter is not turned on when trying to connect. What type of connection does your new ISP provide? (DSL, Cable, Etc.)
    Most likely, some options may need to be or have been changed by accident on your laptop that are required to conenct to your router.
    Now something's you can see is if the router and laptop's wireless channel's are the same. But more information on what wireless settings your router/laptop wireless adapter are may be needed.
  4. #4
    iya
    Newbie
    Singapore
      Thread Starter
    Hi there, thanks!
    At home, I do not have a wireless router so I directly plug the cable to the broadband modem (tied with cable TV). It works perfectly fine on my XP laptop but I only get "Local Only" for my Vista laptop.
    When I was outside yesterday, I used the wireless connection, which also worked fine (same location) before I attempted fixing the LAN problem.
  5. #5
    MDA400's Avatar
    Nvidia and Intel
    Bloomington, MN
    usa us minnesota
    Quote Originally Posted by iya View Post
    Hi there, thanks!
    As of course, there isnt many "settings" for a wired/LAN connection.
    I see that it is a direct connection to your Cable modem though. You can try two things, reinstall the drivers for your ethernet adapter and see if a clean start helps, or you can try to set a static IP that is used by your modem (and you should call your ISP to learn how to do so as it vary's with different connections). Please report on if it still does not work as i may have other solutions that could resolve the issue.
    But try that first and see if anything is cleared up.
  6. #6
    ilikefree's Avatar
    Senior Member
    New Zealand
    Vista Home Premium 32bit.SP2
    Local Time: 03:33 PM
    newzealand
    My subnet mask is 255.255.255.0
  7. #7
    MDA400's Avatar
    Nvidia and Intel
    Bloomington, MN
    usa us minnesota
    Quote Originally Posted by ilikefree View Post
    Yes but that is your router's subnet mask, as is mine. The modem's subnet mask is always different.
Local Only Problem - LAN and Wi-Fi problems?
internet local only problem macdonallds Network & Sharing 3 15 May 2010
ethernet connection problem. local only kmonie360 Network & Sharing 1 16 Feb 2010
Local Only connection problem necr0potenc3 Network & Sharing 14 26 May 2009
local access only problem sleepydumbdude Network & Sharing 1 19 Dec 2008
internet local access only problem!!!please help!!! vargass Network & Sharing 0 09 Sep 2008
