For the last two weeks, I can't connect to the internet. It's says Local Only. When I run the diagnostic, it says...
There might be a problem with one or more netwok adapters on this computer
I tried connecting directly with my cable modem (Motorola SB4100) and I'm still having the same problem. I thought it might had something to do with Norton but it wasn't the case. I got so fustrated that i did a system recovery and yet the same problem occurs.
My current hardware are..
Hp Pavillion m7750n Desktop
Motorola Surfboard SB4100
Netgear WPN824
Windows IP Configuration
Host Name . . . . . . . . . . . . : Arnold-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom 802.11g Network Adapter
Physical Address. . . . . . . . . : 00-12-17-93-C8-90
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
Physical Address. . . . . . . . . : 00-1A-92-25-BB-E0
Link-local IPv6 Address . . . . . : fe80::65d9:ac79:6a0d:e545%8(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.229.69(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . : 0.0.0.0
DHCPv6 IAID . . . . . . . . . . . : 201333394
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Link-local IPv6 Address . . . . . : fe80::5efe:169.254.229.69%17(Preferred)
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Disabled
Please help me with this. Thanks in advanced
