1.    01 Aug 2010 #1
    Vista home premium 32-bit
    Local Time: 01:53
    Wireless does not work
    Hi guys, new here, obviously! I'm having trouble with my internet. When I first got my computer, I never had to go wireless. I used a router and went from there. Now, I have to go wireless, and I have no idea whats going on with it.
    I have tried every avenue to find a solution and have broke down to finding a forum like this. Hopefully you guys can give me a hand? I think my problem is traced down to the hardware or software for the wireless card.
    On the modem itself, the little pamphlet I was able to find, said that if the modem is working a light will be on and if it is active it will blink. I have neither. So I do not know if this means it is broke or if the software is not there for it to work properly.
    I have a Dell XPS 420 with windows vista home premium 32-bit. In the device manager, it say under network adapters:
    - broadcom 802.11g network adapter #3
    - intel(r) 82566dc gigabit network connection
    neither of them have a yellow triangle with a ! next to it. I'm all out of ideas, anyone have anything for me to work off of?
  2.    01 Aug 2010 #2
    New Zealand
    Vista Home Premium 32bit.SP2
    Local Time: 20:53
    newzealand
    Re: Wireless does not work
    go to start type services.msc, press enter
    go to wlansvc see it is set to auto start
    Post back results
  3.    01 Aug 2010 #3
    Local Time: 01:53
      Thread Starter
    Under services.msc I did not find wlansvc. :S
  4.    02 Aug 2010 #4
    Merced & Monterey, CA
    Windows 7 Home Premium 64-bit
    Local Time: 00:53
    usa us california
    Have you tried re-installing the drivers?
  5.    02 Aug 2010 #5
    New Zealand
    Local Time: 20:53
    newzealand
    Quote Originally Posted by hex0rz View Post
    Might be listed as WLAN AUTO CONFIG
    Also go to device manager and expand Network Adaptors
    Look for the wireless adapter (it may be called Atheros )
    Just looked at your post again 802.11g sounds like the adapter
    Right click it and enable
  6.    02 Aug 2010 #6
    New Zealand
    Local Time: 20:53
    newzealand
    When that is done go to Network and Sharing Center, on the left is an entry
    Setup a connection or network. The top box is where you want to set your wireless connection up.
  7.    08 Aug 2010 #7
    Local Time: 01:53
      Thread Starter
    I do not have a cd for the drivers for the network card. I have uninstalled the card from device manager before and then let the ocmputer re-detect it after restarting it.
    I DID find a WLAN AUTOCONFIG under the services.msc, except it was already started on automatic setting.
    Under the device manager it said that it was already enabled.
    When going to the network and sharing center, under connecting to a wireless network, it said there were no available networks. Even though, as I type this, I'm right next to the problem computer with a laptop on the wireless network.
    I don't know if it is true or not, but what about something about the internet copany limiting the amount of people on a given network? Family member was theorizing that I might not be able to access it because this laptop I'm on is on the network already. Except, I oughtta be able to see other networks in the area...
    I never had used the card when I got the computer, so I don't even know if it worked in the first place. I know the computer works, so it couldn't be from it getting jarred around in my move.
    Maybe dell sent me a broken card...
Wireless Internet Won't Work Need Help.
Hello, Ok I have a Compaq Presario V6000 I'm on my home computer right now. My laptop has been working till a few days ago.Then it just stopped...
Network & Sharing
wireless will not work with any adapter
I have a compaq presario desktop that I am trying to connect to a dlink wireless system. I have tried trendnet, linksys, and now Dlink usb wireless...
Network & Sharing
wireless not work after install SP1
Hi, My thinkpad laptop runs Windows Vista. the wireless worked ok before I install Vista SP1. After installing SP1, I only can actually view my...
Vista General
wireless mouse will not work
I have a wireless mouse that installs on my computer running windows Vista Ultimate but won't install on my laptop running Vista Home Basic. All I...
Vista hardware & devices
Wireless used to work but doesn't now
I have a laptop with Vista, The other day all of the sudden the wireless network isn't recognized, I get a message that says I need to install the...
Vista networking & sharing
HELP! Wireless doesn't work, LAN does?
Just installed Vista Ultimate, everything works great but the wireless connection. Previously I ran a Static IP on XP Pro, using Verizon DSL. I have...
Got Linksys wireless USB to work
I was finally able to get the wireless USB Linksys adapter to work on my PC. Here is how I did it: 1. Used the upgrade option from within...
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
