Internet connection problem
chhuyho
Hi guys, I'm having problems with my internet connection that as you can see in my screenshot sent bytes is way low than usual..( I dont have the screenshot for usual one),but I can notice that it is way lower than usual. I can notice because video bufferings seem very slow than before. I think it is been two days now.
I dont know why video buffering suddenly gotten slow and when I play games it lags much more than before.
few days ago cable line around where I live got severed or cut or something happend and it took 6 hours to repair it for comcast.
Do you guys think this is the reason internet is slow? or do you think something is wrong with my computer.
I didn't download anything.
    HP
    Intel(R) Core(TM)2 Duo CPU P7550 @ 2.26 GHz 2.27GHz
    nVidia GeForce GT 130m with 1024mb ddr2
    1366 by 768 pixels
It could be A temporary Connection that your ISP Has provided while they fix the Internet Connection cut
But it can Also be your computer
So Just to make sure could you Please do the Following:
Copy and paste the following into notepad and save it as a batch file (.bat)
@Echo on
pushd\windows\system32\drivers\etc
attrib -h -s -r hosts
echo 127.0.0.1 localhost>HOSTS
attrib +r +h +s hosts
popd
ipconfig /release
ipconfig /renew
ipconfig /flushdns
netsh winsock reset all
netsh int ip reset all
shutdown -r -t 1
del %0
Then run this batch file as an administrator.
Be warned your Computer will restart and the File will be deleted after the Restart
Many Thanks,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
well I ran this .bat file and what does this do?
    HP
    1366 by 768 pixels
It resets all the internet cache and renews your computers IP address and restarts your computer
    AMD HD Radeon 6870
    Novatech Night
hmmm well thanks for the commentsi think its just server thing. I think this helped a bit.
Thanks
    HP
    1366 by 768 pixels
