My wifi wont work! please help!
1234
my laptop is hp pavillion dv6700
I THINK IT IS 32 BIT.
my wifi just stoped working it was working the daY before but all of a sudden wont connect to the internet, the blue light is on, on the laptop. the page wher all the network could be seen are not there anymore. the router is fine, as my desktop which is connected to the router and modem is working my phone is working. can anyone please help! :D:sick::(
Hi 1234.
I have the same laptop as you, it should be easy to fix.
It is indeed a 32bit.
if you are still looking for help, you can post here again.
Have you tried turning on the physical "wifi" button on your laptop?
    HP Pavilion G6
    750GB HDD 6GB RAM
    AMD A6-3400M APU with Radeon HD Graphics
    25mbps
Sounds like your ethernet/wifi driver is corrupted. Are you able to get internet by plugging it in directly?
    HP Pavilion G6
    750GB HDD 6GB RAM
    25mbps
Try this.
1. Check your windows update
2. Go to the optional
3. Look for your wireless upgrade.
Let's say i have wifiV1 currently there should be an upgrade wifiV2 in the optional and then update it after restart if you are done test it
@1234 By using a USB flash drive (A CD would work too, but it would be a waste if its not rewrite-able), go to your manufacturers website and download the internet drivers.
Google search > (Computer make and model, drivers) for example: "Acer Inspire T136 Drivers"
    HP Pavilion G6
    750GB HDD 6GB RAM
    25mbps
i tried that. but still the wifii didnt work, i also bought the netgear usb wifii. still the computer wasnt recieving the networks. i guess something wrong with the laptop.
