| Welcome to Vista Forums we are your forum to discuss Windows Vista x64 and x86 systems. |
| | Thread Tools | Display Modes |
| | #1 (permalink) | ||||||||||||
| Guest
Posts: n/a
| Re: MsMpEng.exe is keeping system busy "Samuel Phung \(eMVP\)" <samuelphung@xxxxxx> wrote:
consuming excessive CPU, it may be conflicting with another process on your PC. If you have any other security package - antivirus, real time antispyware, or similar, uninstall it. If the problem persists, it would be best to contact support to ahve this investigated. How to reach support - http://forums.microsoft.com/WindowsO...21771&SiteID=2 If it fails to validate your subscription, select the option that you are using a trial or beta copy and you can proceed to email support without validation once you've signed in. -steve -- Stephen Boots sboots@xxxxxx Microsoft MVP - Windows Live Windows Live OneCare Forum Moderator http://forums.microsoft.com/windowso....aspx?siteid=2 | ||||||||||||
