If you are having this problem with 2.0, yes. If it is 1.6, then I'd wait to see
if 2.0 resolves it for you.
-steve
"Thomas Grassi" <thomasgrassi@xxxxxx> wrote:
Quote: |
>Steve
>Can I send you the zip file?
>Tom
>"StephenB" <sboots@xxxxxx> wrote in message
>news:coe0h3t2j839v8ejteha8v1j836qgjiv3l@xxxxxx
Quote: |
>>>When will MS fix the issue with WOC? When ever I launch IE 7 Outlook
>>>Express
>>>MMC, or even Outlook Express
>>>MSMPENG.EXE graps all my cpu.
>>>This has been reported on the WOC formums and no one from MS is doing
>>>anything about it.
>>>It also happens launching the Windows Live Onc Care Console
>>>It seems to me that the MSMPENG.EXE is scanning every time an executable
>>>is
>>>launched.
>>>Running 1.6211.32 of WOC
>>>Is there any way to exclude exe files from being scanned all the time.
>>>I tried to exclude iexplorer.exe but it did not change.
>>>Please help
>>>Thanks
>>>Tom
>> Tom, msmpeng.exe is indeed the antimalware portion of OneCare and it scans
>> every
>> file that is accessed. That's what virus scanner do.
>> The problems reported for msmpeng and high CPU have mostly been resolved
>> and
>> I've never seen it reported that it happened for OE or IE7. If it is
>> happening
>> for you, the first thing to verify is that no other real time scanners are
>> conflicting with OneCare - that would be other antivirus or antispyware
>> product.
>> It is possible that an uninstall before you installed OneCare did not
>> remove the
>> product you uninstalled.
>> The latest announcement in the forum requested those that still had the
>> problem
>> to provide detailed log information for review in case there was still a
>> conflicting application that should *not* be causing this issue:
>> http://forums.microsoft.com/WindowsO...55325&SiteID=2
>> -steve
>> Stephen Boots sboots@xxxxxx
>> Microsoft MVP - Windows Live
>> Windows Live OneCare Forum Moderator
>> http://forums.microsoft.com/windowso....aspx?siteid=2 |
