Vista Forums
Vista Forums Home Join Vista Forums Donate Vista Tutorials Store Tags
Welcome to Vista Forums we are your forum to discuss Windows Vista x64 and x86 systems.
Go Back   Vista Forums > Windows Live > Live OneCare > OneCare Backup
Problems restoring files from another system
Thread Tools Display Modes
Old 01-19-2008   #1 (permalink)
Curious
Guest
Posts: n/a
I have a laptop and a desktop both backed up to a network drive using L1C.
My desktop totally died and I need to get files from its backup to my
laptop.
I am unable to do this following the instructions apparently since the
backups are not installed as part of a OneCareCircle.
I have tried changing the name of my laptop to that of my desktop but that
did not work at all.
I certainly never anticipated this problem in advance. Is there a solution?
Old 01-20-2008   #2 (permalink)
StephenB
Guest
Posts: n/a
Re: Problems restoring files from another system
>laptop.
When you perform the restore, you need to select the custom restore option,
meaning a restore from another computer.
If this still doesn't work, the workaround that many have successfully used is
to configure backup on the new PC to point to the same network Share. Create a
new backup - for the sake of efficiency, this backup can be of a single file
type. You can select to backup on Financial files, for example. Perform the
backup and then try the custom restore from the Share.
-steve
Stephen Boots sboots@xxxxxx
Microsoft MVP - Windows Live
Windows Live OneCare Forum Moderator
http://forums.microsoft.com/windowso....aspx?siteid=2
Old 01-20-2008   #3 (permalink)
Curious
Guest
Posts: n/a
Thank you Stephen,
I was using the custom restore option and it would not recognize the backup
files from my desktop since I had not set up a OneCare Circle.
Last night I realized it made complete sense that any user on the network
not to be allowed access to my files just because they had L1C installed on
their system.
I have been able to recover all my files using a USB drive cabinet with the
drive from my old computer installed in it and connecting it to my laptop.
I have to admit that I am a little disappointed in L1C since if you have a
computer and its HDD totally die then when you replace it you can't restore
all of the files from the L1C backup unless you use the procedure you
described.
"StephenB" <sboots@xxxxxx> wrote in message
news:kln6p3l05m25elc7r4seffcfp0ddnuhils@xxxxxx
>>laptop.
>>solution?
> option,
> used is
> Create a
> file
> the
> -steve
Old 01-20-2008   #4 (permalink)
StephenB
Guest
Posts: n/a
You should be able to restore from the network Share with no problems once you
install OneCare on the replaced drive or new PC. The workaround I provided
simply kick starts OneCare if it has trouble with the restore location, which
can happen when it is a Share.
-steve
Quote:
>Thank you Stephen,
>their system.
>described.
>>>laptop.
>>>solution?
>> option,
>> used is
>> Create a
>> file
>> the
>> -steve
Display Modes
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
