br>
Thread Tools | Display Modes |
#1 | ||
Guest
Posts: n/a
I bought and downloaded OneCare onto my Vista laptop. Everything went ok.
Used the setup to install on my tower, a WinXP SP2 machine. It seemed to download files from the web and install just fine but.. I kept getting the error message (i.e it kept appearing over and over - I think it was attempting a connection to the Internet) "Windows Live OneCare Tray Notifcation has encountered a problem and needs to close". Further info: Error signature AppName: winssnotify.exe AppVer 2.0.2500.22 ModName kernel32.dll ModVer: 5.1.2600.3199 Offset: 00012a5b I took the screen shot and didn't realize I needed to scroll down for a second shot. Here is what I saw. (And since I restored back to before I noticed, I can't fint the .txt file it was stored in) Technical information: Exception Information Code: 0xc06d007e Flags: 0x00000000 Record: 0x0000000000000000 Address: 0x000000007c812a5b CPU Vendor Code: 756E6547 - 49656E69 - 6C65746E CPU Version: 00000F41 CPU Feature Code: BFEBFFBFF CPU AMD Feature Code: 00D5E824 Module 1 winssnotify.exe Image Base: 0x31000000 Image Size: 0x00000000 Checksum: 0x0001f4c6 Time Stamp: 0x47969f1a At that point I could no longer connect to the Internet. So I restored to a point before the install. Any ideas? Thanks. |
#2 | ||||||||||||||
Guest
Posts: n/a
The XP machine may have services disabled that are required for it to run or a
required component OneCare depends on may be missing or corrupt. I recommend that you contact support: How to reach support (FAQ) - http://forums.microsoft.com/WindowsO...21771&SiteID=2 -steve "IsisTheCat" <isisthecat47removeme@xxxxxx> wrote:
Stephen Boots sboots@xxxxxx Microsoft MVP - Windows Live Windows Live OneCare Forum Moderator http://forums.microsoft.com/windowso....aspx?siteid=2 |
#3 | ||||||||||||||||||||||||||
Guest
Posts: n/a
thanks. It's too bad the software isn't smart enough to figure that out.
It's the same company fcol! "StephenB" <sboots@xxxxxx> wrote in message news:ioktu35rk791tqkt1sac54alpt9lusmj98@xxxxxx
