Vista - whoever is using a quad core q6600 and generic stock cooling that came with cpu p
Old 11-03-2007   #1 (permalink)
Vista Ultimate x64 Service Pack I
aight guys i got a q6600 that came with the generic stock cooling..everythings at defulats and my cpu is stable at 44 C....that too hot?? or normal
Old 11-03-2007   #2 (permalink)
Re: whoever is using a quad core q6600 and generic stock cooling that came with cpu p
kinda sounds like a dumb question but...i got a SLACR cpu..this is the newer, better G0 processor right?
Old 11-03-2007   #3 (permalink)
Windows Vista x64 Ultimate
Quote  Quote: Originally Posted by mathews2010 View Post
44C isn't too bad, but if that's the idle temp, then you could have a problem when you push the CPU.
You might want to do something to get that temp down by about 10C or so.
Old 11-03-2007   #4 (permalink)
my comp runs like crap now i guess....everytime i turn on my snimpping tool my comp shows 2.4ghz but as soon as i close it it goes back down to 1.6ghz...wat the???
so then my ai suite tells me 1.6 ghz...and its using 44 C for 1.6 ghz..!!
i can t even go up to 2.4ghz without hitting like 60 C
i mean this is generic stock cooling..but it cant be that bad can it?
also if sum1 could help me add a pic from the snipping tool..i could kind of show u the stats
Old 11-03-2007   #5 (permalink)
Windows Vista X64
yep SLACR means its the new G0 Stepping.
As for the 2.4Ghz to 1.6Ghz,i think its the Speedstep thts kicking in .you can disable that in the BIOS if u dont want it to underclock your CPU but you could save some power if its on.
The temps seem fine for Stock Cooling,get better cooling (Thermalright Ultra120 and the likes) if you want to overclock it and see a big improvement in temps.
Old 11-04-2007   #6 (permalink)
vista ultimate x64
You should be able to drop the vcore pretty much if your running stockspeed.
I can have Vcore 1.2625 @ 3.2ghz, dont remember what i had for stockspeed.
But check ur Vcore and im sure you can go below what you have now.
Run Prime95 to make sure your stable as you go down step by step.
//Cyn
EDIT: Right now im runnig my pc at 3.6ghz and Vcore 1.5 in bios (true volt is 1.44V with Cpu-Z). Temps are about 42C idle and 65C 100% load on all cores.
Old 11-04-2007   #7 (permalink)
Vista Ultimate x64
I replied to your "on/off" post....
just wondering... is this your first PC build?
« - | Speedfan »
Speed problem with Intel Q6600 (Quad Core) and Ultimate 64-Bit Vista performance & maintenance
Intel: Core i7 to Be Up to 52% Faster Compared to Core 2 Quad. Vista News
Vista X64 and Intel's Quad Q6600 OC'd to 3GHz Vista performance & maintenance
Anyone have a P5K Board, q6000, and stock cooling.. Overclocking & Cooling
Which version support dual core or quad core? Vista General
