| Vista Ultimate x64 Service Pack I | selecting the best fans and heatsinks ok well first of all i got arctic silver 5 thermal paste..which is one of the best i heard...and i have the crappy stock cooling that came with the cpu.. it is a q6600, so i need one for an lga 775 socket thermalright ultra 120 or a zalman cnps9700 or a scythe infinity? which one would be the best of oc'ing and best cooling and performance? Last edited by mathews2010; 11-07-2007 at 10:09 PM.. |
| Vista Ultimate x64 SP1 / Windows 7 Ultimate x64 | Re: selecting the best fans and heatsinks ok well first of all i got arctic silver 5 thermal paste..which is one of the best i heard...and i have the crappy stock cooling that came with the cpu.. it is a q6600, so i need one for an lga 775 socket thermalright ultra 120 or a zalman cnps9700 or a scythe infinity? which one would be the best of oc'ing and best cooling and performance? |
| Windows Vista X64 | Re: selecting the best fans and heatsinks Ye[ the TRUE(ThermalRight Ultra Extreme) along with a good FAN is supposed to be the best HSF for air cooling. If it doesnt fit in your case (check the dimensions on Thermalright's website) then get the ThermalRight Ultima-90. |
| Vista Ultimate x64 Service Pack I | Re: selecting the best fans and heatsinks i got a full atx case..so get a thermal right ultra 120 with a 120 mm fan right? not sure about the ram cooling yet..maybe later..dont use much ram |
| Vista Ultimate x64 Service Pack I | Re: selecting the best fans and heatsinks hmm not so sure if i wanna go for a thermalright with a fan...kinda big...and prolly wont need that much..the zalman cnps9700 looks reasonable and is well rated...any idea how much ur temps would be at idle with oc'ing? |
| | #6 (permalink) |
| Windows Vista X64 | Re: selecting the best fans and heatsinks i live in india ,the temps here are always hot,so no use comparing my Idle/Load temps. Get the Ultima-90 if you dont wanna get the 120 version,i think its better than the Zalman. |
| | #7 (permalink) |
| Ultimate x32 | Re: selecting the best fans and heatsinks Get an Arctic Cooling Freezer Pro if you want to basically turn your CPU into a Popsicle. No really its an excellent cooler, just read the reviews over on Newegg. |
| | #8 (permalink) |
| Windows Vista x64 Ultimate | Re: selecting the best fans and heatsinks I've found the ThermalTake series of coolers to be fairly cool. No Pun intended. Is use the ThermalTake Tai-Chi chassis with built-in water cooling. My CPU has never gone higher than 36C, even on a typical South African summer day. |
| | #9 (permalink) |
| Vista Ultimate x64 SP1 / Windows 7 Ultimate x64 | Re: selecting the best fans and heatsinks With slightly overclocked cpus', (3.24GHz vice 3GHz), my idle temp right now is 34 -35. I'm using speedfan: 19 - 20 plus 15. Under heavy load 57 -58. Take in consideration I have the stacker 830 with four 120s', 1 front, 1 side (both intakes), 1 back and one top (exhaust). |
| | #10 (permalink) |
| Vista Ultimate x64 Service Pack I | Re: selecting the best fans and heatsinks hey asky...i know where your at..my parents were born in india, and i just went there this summer..and ur in bombay i believe, or now known as mumbai... oh yeah might wanna think some more on the fan |
| wow fans? | Gaming | |||
| Any Sims 3 Fans???? | Chillout Room | |||
| Fans | Overclocking & Cooling | |||
| new tower fans | Overclocking & Cooling | |||
| CPU Fans and heatsinks | Vista hardware & devices | |||
