Vista - thermal right ultra 120 extreme cooler or zalman cnps9700
Old 11-23-2007   #1 (permalink)
Vista Ultimate x64 Service Pack I
not sure which to choose...prices are both reasonable and near by...
was think about the thermal right because its known for better cooling that the zalman..but the zalmans a LITTLE more compact...anyone know how much of a temp difference these fans would make? 5C? or more? for the thermal right..
also i got a full atx case, so im guessing i can jam it in there...maybe
check if it might fit and give me a heads up...theres an image below
Old 11-24-2007   #2 (permalink)
Windows Vista Ultimate x64 bit
Re: thermal right ultra 120 extreme cooler or zalman cnps9700
I am running the CNPS9700 and it works great for my OCed Q6600.
ALMAN 9500A 92mm 2 Ball CPU Cooler with evga 790i ultra sli Overclocking & Cooling
Thermal Electric CPU Cooler Overclocking & Cooling
Ultra-ultra slow! Vista performance & maintenance
8800 Ultra Extreme had missing PCI_E power onboard Graphic cards
CPU Thermal Compound and Thermal Grease. Which is better? Vista hardware & devices
