Vista - Overclocking problems, Oc fine in XP, but the smallest overclock in vista = freeze
Old 12-19-2007   #1 (permalink)
Vista Ultimate x64 SP1 RC1
As the title says, ive managed to overclock to 3.8ghz really stable in XP. But vista wont take anything. my rig is below the stock fsb is 1333 i put it to 1350 and it still froze. What am i doing wrong, i see people online have overclocked in vista just the same.
Rig
Intel E6750 @ 2.67
P5N-E SLI
2x WD 500gb hdds
2gb Apacer Ram (2x 1gb)
Zalman 9700NT cpu fan
XFX 8800GT
Thanks in advance for help.
Edit: btw it freezes every time about 30 secs after i see my desktop. Usally just after Nod32 smart securty loads. do you think this could be the problem?
Old 12-19-2007   #2 (permalink)
Vista Ultimate 32/Windows 7 Dual Boot
Re: Overclocking problems, Oc fine in XP, but the smallest overclock in vista = freez
Yer, I dont think its Vista..its probably something you installed. Ill bet if you had a clean install without any extra programs, then it would overclock fine.
Now finding which program is causing the problem..well thats another story.
Old 12-19-2007   #3 (permalink)
well i got the upgrade version from the ms website. so i got 64bit xp off my friend then istalled it so i cant do a new reinstall. could this be part of the problem?
Old 12-19-2007   #4 (permalink)
Hey ppl ive fixed it. It was Ntune. was loading a profile and freezing my pc as it dont like changeing cpu from ntune. Thanks for your help coolchris, im sure i would have eventually cheaked programs. but you saved me alot more googling. (spent the last week trying to find out :S)
thanks again,
Aaron
Old 12-19-2007   #5 (permalink)
vista Ultimate X64 SP1
hey pal....i see u overclocked it to 3.8Ghz. I wanna know if its worth the overclock. Im an avid gamer and stuff. Im about to build a new comp in 2 weeks so just wanna know if i should really go in for a processor cooler right now.
moreover with the q6600 whats the max that i can overclock with the stock cooling??
Old 12-19-2007   #6 (permalink)
ive had my cpu at 4ghz but it seamed stable but it rebooted my pc after about 10 secs of orthos. the Q6600 is a very hot cpu. stock its at 2.4ghz. Under stock cooling your looking at maybe 3ghz. at about 60-70 degress underload. This is to much for me. I have a Zalman 9700NT and at 3.8ghz my cpu is idling at 38degress and load is about 46.
hope this helps.
Old 12-19-2007   #7 (permalink)
Windows Vista X64
Wow those are very nice Temps for a 3.8Ghz Q6600.
You must be living in a very cold area Chipmunk.
Old 12-19-2007   #8 (permalink)
Vista Ultimate x64 Service Pack I
actually chipmunk i am havn the same prob...urs may be solved but mine...not so great..im really scared of ocing now...my screen freezes and i like raise my speeds from 266 to 270...then it says ocing failed...so i reset my bios...my times screwed up now...control panel isnt working..welcome center crashes...and im like?? i did do a bios revison and havent tried ocing after that....prolly will..but jus too scared...dont wanna do a clean install again...prolly done 10 of them in 2 months after i built my comp...
The Best way to overclock on Vista Overclocking & Cooling
LifeCam VX-6000 freeze problems. .NET General
Does Overclocking YOur CPU cause problems with your activation? Vista General
Antivirus: Smallest update file sizes? Vista security
URL Shortcuts are black at smallest size! Vista General
