| | #21 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: CPU OC Wall? SOrry for the Double Post, but the board only allows for so many quotations per post.... loco - first off you'll need to decide whether you can live with high temps or not - either you have a very poor cooler, or it was poorly installed. I haven't seen temps like yours with my OCed system *at full use* - In fact, I've never see 55 deg C yet.... As for my mobo being better to OC, according to Fumz, it ain't so good - DFI seems to be the way to go in terms of true OC-ability, but I picked this as a nice balance between enthusiast and run of the mill generic boards. I might look into another machine in a year (I've been bitten by the bug, I want to build a truly powerful rig this time - hopefully for under $3000 USD) My point is that heat isn't what kills a cpu quickly. The cpu in question can handle up to 70C. More importantly, it shuts itself off if it gets too hot. Yes, more volts generate more heat; however, the Tuniq is one of the best air coolers out there and yes, it's much better than "a cheaper one": AnandTech: Thermalright Ultra 120 Extreme: Is More Better? But again, heat, per se, isn't a problem, it's volts. A cpu on water being over-volted has a much greater potential to suffer the quick death that alot of over-volted cpu's suffer. My point, is that the price of the water cooling unit would not justify the gains since he's already near the limits of safe voltage on air and doing just fine. The only thing water would do, aside from cost a lot, is to give a false sense of security that you could safely over-volt the cpu... and this just isn't true. I am guessing that even at 3.6 GHz my CPU will not be trying to drain the system of above 1.5 V, but this is theory on my part, based upon the MCP cooling issue these boards have. And, you're right, Fumz, I should actually be quite happy with a 33%OC, back in the day 15% was astounding, until Intel started binning CPUs heavily. |
| | #22 (permalink) |
| Vista Ultimate 32/64 bit | Re: CPU OC Wall? Quote: loco - first off you'll need to decide whether you can live with high temps or not - either you have a very poor cooler, or it was poorly installed. I haven't seen temps like yours with my OCed system *at full use* - In fact, I've never see 55 deg C yet.... |
| | #23 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: CPU OC Wall? You can live with the temps - now - but as soon as you OC they'll go up....hence my point. |
| | #24 (permalink) |
| Vista Ultimate 32/64 bit | Re: CPU OC Wall? There is no fan attatched to that Tuniq is there? Picasa Web Albums - johnlgalt - The Beast That thing is a monster isn't it.....never mind I found the midship fan ( Tuniq - Tower 120 Cooler). EDIT: If you want to go for that Scythe/TRUE120 cooler combo, I'll take the Tuniq off your hand for a fair price. Last edited by locoeng; 08-10-2008 at 10:34 PM.. |
| | #25 (permalink) |
| Vista Ultimate x64 SP1 | Re: CPU OC Wall? The fan is inside the heatsink... smack dab in the middle. |
| | #26 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: CPU OC Wall? lol loco - I was looking to replace the fan part only. That Tuniq is a beast, but for under $50 USD I can't complain at its sheer cooling power for an Air cooler. |
| | #27 (permalink) |
| ultimate 64 SP1 | Re: CPU OC Wall? hey fumz... isn't it amazing how far the clocks can go when the chip is kept cool.... ![]() yes its LN2 but he is probably pushing 2.0v vcore through a 45nm chip to get that so i still stand by the fact that heat plays a bigger part than volts ![]() Andre Yang, a civil engineer doing his PhD. in the US obtained a high-performing Core 2 Duo E8600 processor, he succeeded in overclocking this chip to a stellar 6.70 GHz clock-speed (FSB 672.16 x 10.0). The processor uses liquid-nitrogen (LN2) cooling and surprisingly this processor was overclocked on a motherboard with the Intel X48 chipset, the ASUS Rampage Extreme when previous record-holders across several recent processors made use of either the Intel P35 or P45-based motherboards. john .....that is still a sweet OC & i was not suggesting you buy a WC setup ....i was merely stating i think you hit your limit on air. |
| | #28 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: CPU OC Wall? I know you weren't, skunk |
| | #29 (permalink) |
| Vista Ultimate x64 SP1 | Re: CPU OC Wall? hey fumz... isn't it amazing how far the clocks can go when the chip is kept cool.... ![]() yes its LN2 but he is probably pushing 2.0v vcore through a 45nm chip to get that so i still stand by the fact that heat plays a bigger part than volts ![]() Andre Yang, a civil engineer doing his PhD. in the US obtained a high-performing Core 2 Duo E8600 processor, he succeeded in overclocking this chip to a stellar 6.70 GHz clock-speed (FSB 672.16 x 10.0). The processor uses liquid-nitrogen (LN2) cooling and surprisingly this processor was overclocked on a motherboard with the Intel X48 chipset, the ASUS Rampage Extreme when previous record-holders across several recent processors made use of either the Intel P35 or P45-based motherboards. john .....that is still a sweet OC & i was not suggesting you buy a WC setup ....i was merely stating i think you hit your limit on air. ![]() ![]() Nobody argued heat wasn't a factor, it's just not a factor here. It's also true that as you increase vcore heat rises exponentially. Nobody said anything different; but again, heat's not really the issue here as johngalt's temps are well below 70C. It's also true that you can get some insane sub-zero clocks as you're able to pump tons of volts into the core and keep the cpu cool enough to operate. However, electromigration occurs no matter what. It's brought on first and formost by volts. Heat exacerbates the problem, but it's still the volts that kill cpus. It really doesn't matter how cool you're able to keep a chip, over-volting is going to kill it. Nobody runs LN 24/7. Chips just don't last that long under that kind of voltage. While it's a neat feat, it's wholly unrealistic as an option for the normal user. Watercooling comes nowhere near phase or LN. As it applies here, since we're already talking about a vcore of 1.45, it's really not worth the cost. He'll maybe shave 5C off his current temps, which are already very low given the voltage. |
| | #30 (permalink) |
| ultimate 64 SP1 | Re: CPU OC Wall? hey fumz... isn't it amazing how far the clocks can go when the chip is kept cool.... ![]() yes its LN2 but he is probably pushing 2.0v vcore through a 45nm chip to get that so i still stand by the fact that heat plays a bigger part than volts ![]() Andre Yang, a civil engineer doing his PhD. in the US obtained a high-performing Core 2 Duo E8600 processor, he succeeded in overclocking this chip to a stellar 6.70 GHz clock-speed (FSB 672.16 x 10.0). The processor uses liquid-nitrogen (LN2) cooling and surprisingly this processor was overclocked on a motherboard with the Intel X48 chipset, the ASUS Rampage Extreme when previous record-holders across several recent processors made use of either the Intel P35 or P45-based motherboards. john .....that is still a sweet OC & i was not suggesting you buy a WC setup ....i was merely stating i think you hit your limit on air. ![]() ![]() Nobody argued heat wasn't a factor, it's just not a factor here. It's also true that as you increase vcore heat rises exponentially. Nobody said anything different; but again, heat's not really the issue here as johngalt's temps are well below 70C. It's also true that you can get some insane sub-zero clocks as you're able to pump tons of volts into the core and keep the cpu cool enough to operate. However, electromigration occurs no matter what. It's brought on first and formost by volts. Heat exacerbates the problem, but it's still the volts that kill cpus. It really doesn't matter how cool you're able to keep a chip, over-volting is going to kill it. Nobody runs LN 24/7. Chips just don't last that long under that kind of voltage. While it's a neat feat, it's wholly unrealistic as an option for the normal user. Watercooling comes nowhere near phase or LN. As it applies here, since we're already talking about a vcore of 1.45, it's really not worth the cost. He'll maybe shave 5C off his current temps, which are already very low given the voltage. i DO NOT believe he should buy a WC setup to further his OC but i do think there is only so far you can go on air...... would you not agree...? i still believe that in ''domestic systems'' heat is still more of a factor than volts as electromigration will take far longer to have an effect than say someone with a 40c ambient resulting in a 50 or 60c idle...(its just an example) |
| Wall-e 2 ? | Vista music pictures video | |||
| GOING UP THE WALL TRYING TO INSTALL 64 bit programs | Vista General | |||
| wall paper | Vista performance & maintenance | |||
| windows will not sav wall paper after rebote | Vista General | |||
| wall paper | Vista music pictures video | |||
