Vista - Uh-Oh are my main components too hot!?!
Old 08-18-2008   #1 (permalink)
WIndows Vista Ultimate 32 bit (x86) SP1
I have a question about hardware which I am not to savvy with yet. What are the healthy temps for each? And the max? Are the temperatures too high?
Old 08-18-2008   #2 (permalink)
vista ultamate 64bit
Re: Uh-Oh are my main components too hot!?!
they are a little warm but id say nothing to worry about
Old 08-18-2008   #3 (permalink)
Windows 7 x64
CPU just a bit too warm I think, but rest seems alright to me really.
Old 08-18-2008   #4 (permalink)
Win XP Pro / Win Vista Ultimate
those temps are fine
make sure to clean the fans with compressed air often just to make sure you always have them clean
Old 08-18-2008   #5 (permalink)
Is there a better/cheaper fan I can invest in? nor is it not necessary? it is pretty hot in my room probably thats why.
Old 08-18-2008   #6 (permalink)
Quote  Quote: Originally Posted by isikh View Post
that will do it however be sure to do what motarola2 said and blow out you PC with compressed air to stopp the fans and cooling radiators from clogging up
Old 08-18-2008   #7 (permalink)
it hasn't even been a month since i built this computer and i built it in a clean enviorment i doubt its dust also that is all idle while running firefox a movie using vlc on my hd sidebar on hardware monitor and thats about it
this is it now..idle with firefox
Old 08-18-2008   #8 (permalink)
http://img393.imageshack.us/img393/1156/capture2ab8.jpg
i don't have much spaceb il try speedfan and post back also this is it with crysis running, ie, firefox, aim, task, manager, sidebar, pinacle game profiler,hamachi
Old 08-18-2008   #9 (permalink)
Vista Ultimate x64
How are your case fans set up? Front and side (if present) blowing in, and rear and top (if present) blowing out?
Old 08-18-2008   #10 (permalink)
actually screw it if it is screwed it will auto shutdown i did sum research this can be deleted
COM+ / NET Components .NET General
Hkey_local_machine\components Vista General
Re Usable components .NET General
Do I need these Windows components? Vista General
Can't add Windows Components Vista installation & setup
