Vista - Post Your Overclock Results.
Old 10-11-2008   #101 (permalink)
Vista Ultimate x64
Re: Post Your Overclock Results.
getting up there. be careful or get better cooling
Old 10-11-2008   #102 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
I need to take new pics and update my stats, as well as get new Vantage scores. I suppose I should get 3dMark '06 and run it once now that I have these SLI'd and slightly OC'd, huh?
Old 10-12-2008   #103 (permalink)
ultimate 64 SP1
she just keeps on truckin!!....lol
i think i have hit my RAM limit again this is 100% stable so i will leave it here for now.
SK
Old 10-12-2008   #104 (permalink)
Vista Ultimate 64bit SP2/
Nice oc skunksmash
Old 10-12-2008   #105 (permalink)
Vista Ultimate x64
Well done mate, I knew you would get there. Take that xguntherc lol
Old 10-12-2008   #106 (permalink)
ultimate 64 SP1
LOL....... thanks all!!
SK
Old 10-12-2008   #107 (permalink)
vista home premium SP1 32bit
hi lads, i been lookin at gettin an upgrade MOBO,, what is you opinions on the
XFX nForce 790i Ultra SLI Motherboard with a
OCZ 600GXS Sli -UK nVidia SliReady600W
i currently have a standard acer mobo and cant OC hardware as follows: quad Q6600 2gb ram 500gb ata nVidia 8400gs (512mb i think lol) just gonna transfer everythin over and then go for gold on an OC.. one problem... havent a clue how to OC gonna give it a go tho..
your onpinions on the upgrade hardware are much needed
thanks...
Old 10-12-2008   #108 (permalink)
ultimate 64 SP1
looks good mate........
but i would seriously consider upgrading your GFX card at the same time, the 790i will be wasted with an 8400
In regards to OCing you may want to take a look at This when its all up & running.
SK
Old 10-12-2008   #109 (permalink)
Vista Ultimate x64
Quote  Quote: Originally Posted by scousa4lyf View Post
thanks...
I think that is a great motherboard, but unless you have two or more graphics cards and DDR3 memory then it's probably not for you, you might want to try the Evga 750i SLI FTW.
That's the one I just got and it's great for overclocking had my E8500 @ 4.5Ghz plus it takes DDR2 Memory and still has two PCIE x16 2.0 slots
Just in case you aren't aware, if you change motherboards you will need to reinstall windows and make sure when you do that you only have 2GB of ram installed otherwise you might have problems installing Vista.
Old 10-12-2008   #110 (permalink)
chances are i am gonna buy all brandnew hardware anyway and just sell this pc, buy the same q6600 processor again tho... i can understand going for the evga but the appeal of the xfx is more i think...
can i ask. what is the reason for using only 2GB when installing vista.. i was planning on getting 4GB... do i use 2gb and then after installation of vista, add the other 2GB, the board can support upto 8GB.
also, you mentioned two or more GPU's.. can this not just be run with one or will certain features not function correctly
thanks mate
I7 920 overclock Overclocking & Cooling
Post your over-clocking results Overclocking & Cooling
can overclock gpu Overclocking & Cooling
Ati Overclock Graphic cards
Should I Overclock? Overclocking & Cooling
