| | #141 (permalink) |
| Vista Ultimate x64 | Re: Post Your Overclock Results. |
| | #142 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: Post Your Overclock Results. Hmmm - I haven't tried entry level yet - I always try the level recommended for my computer, P? I cannot remember - new Vista install and I haven't gotten around to installing Vantage again.... I should try that with my dual GTX 260s and my OC'd 6600....so I can justify buying a 9650 |
| | #143 (permalink) |
| Vista Ultimate x64 | Re: Post Your Overclock Results. Hi John, That is something I would like to see as I was wanting to get a second one myself to put in SLI, please post some 3DMark06 results as well. How long have you had two of those cards and how come you haven't posted your results? You have been holding out on us lol. |
| | #144 (permalink) |
| ultimate 64 SP1 | Re: Post Your Overclock Results. nice setup Mr Grim!!! & sweet OC...... i see you grabbed the 216 260, these appear to be great performers i will be snapping one up when i can work my other half around the need to upgrade my 88GT ![]() SK |
| | #145 (permalink) |
| Vista Premium x64 | Re: Post Your Overclock Results. This is on recommended test, never thought about a basic one either. |
| | #146 (permalink) |
| Vista Premium x64 | Re: Post Your Overclock Results. Entry Level Test looks so bland but here it is. Mr Grim would like to see a performance test on your system |
| | #147 (permalink) |
| Windows 7 Ultimate x64 | Re: Post Your Overclock Results. Recently I bought new case for my PC - an AeroCool S9 Pro, with a huge side fan. As this case is much wider than my previous one I decided to change my CPU cooler as well So I bought Scythe Mugen (Infinity) I also added two Noctua NF-P12 120mm fans to blow the air in and out of the case (one of them replaced the standard 120mm fan that came with the case, as it was too noisy) ![]() After 30 minutes of stress testing in orthos temperature on my CPU stabilized at 49C! And my CPU is overclocked to 3.73GHz This is just awesome result, as my previous cooler under load achieved 65C Idle temp is 33C, but this is the lowest temp that my MB can display for the CPU, unfortunately. I bet that the idle temp is lower than that The cooler was definitely worth the money Now with this new case entire system temp is 30C, under full load (and I mean while gaming i.e. in Crisis) it increases just to 34C! ![]() When I get my hands on the camera I'll post some photos of my current setup |
| | #148 (permalink) |
| Windows 7 Ultimate x64 | Re: Post Your Overclock Results. I finally got some photos of my system So like I said before, here they are: ![]() ![]() |
| | #149 (permalink) |
| Vista Ultimate SP2 x64 : Seven Ultimate x64 | Re: Post Your Overclock Results. Now that's a side fan What sort of noise do you get with it? |
| | #150 (permalink) |
| Windows 7 Ultimate 32 bit Beta, Vista Ultimate x86 | Re: Post Your Overclock Results. Those Noctua fans are great, aren't they. Sooo quiet. Shame about the colour though. I have 2 x 140mm. Cut my case noise right down. |
| I7 920 overclock | Overclocking & Cooling | |||
| Post your over-clocking results | Overclocking & Cooling | |||
| can overclock gpu | Overclocking & Cooling | |||
| Ati Overclock | Graphic cards | |||
| Should I Overclock? | Overclocking & Cooling | |||
