Vista - Post Your Overclock Results.
Old 05-08-2009   #201 (permalink)
ultimate 64 SP1
Re: Post Your Overclock Results.
4ghz....finally.
what do ya reckon..., check the FSB on that bad boy.....
13sec superPI
1150mhz @ CL5 ...(8GB )
she's stable but its swallowing 1.5v to keep her there, i hit 70c yesterday after an hour on GTA4 ....i need a new cooler
SK
Old 05-08-2009   #202 (permalink)
Win7 Ultimate 64bit
Here is mine..can't remember if I've posted this or not ??? if so..sorry for the repost
Old 05-08-2009   #203 (permalink)
ultimate 64 SP1
....... nice fatboy
SK
Old 05-08-2009   #204 (permalink)
Win7 Ultimate 64bit
Quote  Quote: Originally Posted by skunksmash View Post
....... nice fatboy
SK
Thanks..your numbers look good also. Is it Prime95 Stable? And I would defiantly get a new cooler.
Old 05-08-2009   #205 (permalink)
Windows 7 x64
4ghz....finally.
Attachment 12685
13sec superPI
Attachment 12686
Attachment 12687
SK
Very nice
Pushing that thing to the limit before switching to a C2Q?
Old 05-09-2009   #206 (permalink)
ultimate 64 SP1
Quote  Quote: Originally Posted by Everlong18 View Post
4ghz....finally.
Attachment 12685
13sec superPI
Attachment 12686
Attachment 12687
SK
Very nice
lol...... where you hiding that crystal ball Everlong..?? , yep thats the plan...
im gonna do a torture run today @ 1.6v....... lets see how high an FSB this board is good for, all the reviews said it stops dead @ 490mhz ..?? 520mhz here i come.....
SK
Old 05-09-2009   #207 (permalink)
Win7 Ultimate 64bit
SK
Smoke 'em if you got 'em
Old 05-09-2009   #208 (permalink)
ultimate 64 SP1
ok....... that didn't go at all well , pushing just 1mhz above a 500FSB actually caused all sorts of BIOS corruption....
i thought i had lost her at one point, she failed to boot AT ALL & the CPR failed to work, so i had to pull my GPU out & reset the CMOS manually & she came back to life...
so i think this boards limit is 500FSB, im pretty sure the chip was good for more (even though its a furnace at those frequencies...lol)
i will get a quad with a high multi & see how far i can push that (eventually)
SK
Old 05-16-2009   #209 (permalink)
Windows 7 Ultimate x64
I've got a small question... When I enter BIOS and see the value of VCore, it's 1.393V, but when I go to the Hardware Monitoring tab in the BIOS the value for the VCore is 1.360V... I know that some motherboards can't maintain desired voltage, or they can't report actual real value... I just would like to know which value should I believe - the one that I set up, or the one that the BIOS reports to me in the hardware monitoring tab.
Old 05-17-2009   #210 (permalink)
ultimate 64 SP1
Hi Majkel......
i'd be inclined to belive the ''monitoring tab'', the reading under the CPU stats could be its ''VID'', not current voltage.....
SK
I7 920 overclock Overclocking & Cooling
Post your over-clocking results Overclocking & Cooling
can overclock gpu Overclocking & Cooling
Ati Overclock Graphic cards
Should I Overclock? Overclocking & Cooling
