| | #241 (permalink) |
| Vista Ultimate SP2/Windows 7 Ultimate x64 | Here's my modest OC result. Temps are OK - around 59ºC for CPU and 52ºC for the MB. |
| | #242 (permalink) |
| Vista Ultimate x64, SP2 | |
| | #243 (permalink) |
| Vista Home Premium x64 | How did you get a x29 when the extreme only gets x24? My i7 only is limited to x20 as it was one of the first i7's out |
| | #244 (permalink) |
| Vista Ultimate SP2/Windows 7 Ultimate x64 | In BIOS 1. Load defaults under AI tweaker by clicking F5. 2. Disable Intel Turbo Mode Tech 3. Change CPU Ratio Setting to 29 (type in manually) 4. Change CPU Voltage to 1.4 (type in manually) Save settings and exit (F10). |
| | #245 (permalink) |
| Win7 Ultimate 64bit | |
| | #246 (permalink) |
| Vista Home Premium x64 | That i w sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet. aaaThanks |
| | #247 (permalink) |
| Vista Home Premium x64 Sp2 | Re: Post Your Overclock Results. Last edited by maxx1973; 09-07-2009 at 09:17 AM.. |
| | #248 (permalink) |
| windows 7 home premium 64 bit | Re: Post Your Overclock Results. my over clocking result temps are around 38 when idle and around 67/68 when runing prime 95 in the picture prime 95 has been runing for just under 15 hours |
| I7 920 overclock | Overclocking & Cooling | |||
| Post your over-clocking results | Overclocking & Cooling | |||
| can overclock gpu | Overclocking & Cooling | |||
| Ati Overclock | Graphic cards | |||
| Should I Overclock? | Overclocking & Cooling | |||
